5 lug conversion progress, my Christmas present |
Thack |
Jun 13 2006, 05:18 PM
Member Group: Members Posts: 283 Joined: 1-June 05 From: Houston, Tx Member No.: 4,182 |
So the rotor bolts up behind the hub and the wheel lugs onto the hub directly or is the photo just showing the part. The hub looks like a spacer/adapter because there are other holes inside.
michelko |
Jun 14 2006, 01:05 AM
Senior Member Group: Members Posts: 867 Joined: 30-November 03 From: Germany, Lambsheim Member No.: 1,404 Region Association: None |
Hi,
this is all bone stock, no spacers or anything else. And yes its a 911 setup. I will run 6*15 Fuchs on it. (IMG:style_emoticons/default/smilie_flagge6.gif) |
Stieve |
Jun 14 2006, 01:07 AM
Senior Member Group: Members Posts: 587 Joined: 6-May 06 From: Sacramento Member No.: 5,996 |
I want some...need money though
michelko |
Jun 15 2006, 03:29 AM
Hi,
now i am mounting all the parts together. Here is a trailing arm with bearing and the cover plate. Unfortunately the batteries of the camera went south, so no more pics for now Installed also the the 5 lug hub. Will post pics of it later. (IMG:style_emoticons/default/smilie_flagge6.gif) Attached image(s) |
turboman808 |
Jun 15 2006, 04:51 AM
Advanced Member Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States |
I had some nice pretty lug nuts like that yesterday. Then I decieded I wanted the ends to be open (IMG:style_emoticons/default/sawzall-smiley.gif)
michelko |
Jul 17 2006, 04:06 AM
Hi there,
the story continues: id the front axle conversion. No major problems, only the right big nut that hold the balljoint won´t come of. So had to grind it it of again!! Attached image(s) |
michelko |
Jul 17 2006, 04:10 AM
Here are the pics withe that nice fuchs rims. I love them!! (IMG:style_emoticons/default/wub.gif)
rear axle to go. I have all needed parts, sothis should be done in no time. If there are no more nuts ore screws that won´t come off. (IMG:style_emoticons/default/smilie_flagge6.gif) Attached image(s) |
michelko |
Sep 1 2006, 01:33 AM
Hi there
it´s already done (IMG:style_emoticons/default/burnout.gif) all four corners equiped with that realy nice fuchs rims. Had no major problems on the conversion. Had the part sandblasted and painted them with por15. New bearings, screws, etc. 911 hub Dustshields also sandblasted and painted |
michelko |
Sep 1 2006, 01:37 AM
right side ready left side to go
nother shot of the left side without the breakdisk I am realy happy with the look of the car now but that steel wheels wasn´t so bad. (IMG:style_emoticons/default/smilie_flagge6.gif) |
So.Cal.914 |
Sep 1 2006, 01:45 AM
A very clean install, now you just need to post some pic's of the finished product.
(IMG:style_emoticons/default/smile.gif) |
michelko |
Sep 1 2006, 08:24 AM
Tada...
here is the car with fuchs on all four corners. other side.. Today and tomorow is the "Vorderpfalz Classic" i will post pic´s later. Some Porsche content. (IMG:style_emoticons/default/smilie_flagge6.gif) |
Root_Werks |
Sep 1 2006, 08:39 AM
Village Idiot Group: Members Posts: 8,426 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/smilie_pokal.gif) Fantastic work as always! I love your threads and all the work you have done to your 914. Great progress! (IMG:style_emoticons/default/driving.gif)
Lo-Fi Version | Time is now: 27th September 2024 - 06:23 PM |
