Porsche Rescue |
Saving and Enjoying Old Porsches ![]() ![]() ![]() ![]() Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None ![]() |
Brad asked for some pics of the AC I am removing from my latest project, 1970 914-6 bought on Ebay from SoCal.
First I have seen on a six but looks much like the 4 systems I've seen. Firewall was notched for the compressor but it is a pretty good job. Here it is. Attached image(s) ![]() |
Porsche Rescue |
Whoever installed removed the fresh air fan box, cut a hole below it (don't understand why) and plugged the fresh air grill on the cowl. Fresh air is fed to the underdash unit by two tubes, one in each front wheel well (Why not use the original fresh air feed, less holes for me to plug?).
Porsche Rescue |
Here is the underdash unit, DPD.
Porsche Rescue |
Then we have the real marvel, an oil cooler plumbed with copper sitting on top of the condenser.
Porsche Rescue |
Only good thing about this installation is the hole in the front trunk floor, usually they are larger!
tryan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 553 Joined: 22-January 03 From: smokey mountains gatlinburg tn Member No.: 184 ![]() |
did the pilgrims use that compressor on the mayflower?
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,373 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
And the worst type of oil cooler to use. Those tubes do just about nothing to cool the oil.
Paul |
fiid |
Turbo Megasquirted Subaru Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California ![]() |
Is it bad to use copper for plumbing automotive stuff - I am wondering about what I should use for water pipes for my watercooled conversion.
Fiid. |
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,623 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
Well Brad...
So far it looks like we'll be notching our firewalls. Steve |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
QUOTE(fiid @ Aug 29 2003, 01:05 PM) Is it bad to use copper for plumbing automotive stuff - I am wondering about what I should use for water pipes for my watercooled conversion. people do it. it's probably not a big deal when using substantial-size tubes for water. the issue with copper (and aluminum) is that it work-hardens from the vibration flexing and cracks and breaks. little tubes can vibrate and flex; big tubes - not nearly as likely. i'd think (but have no first-hand knowledge - so this is just armchair engineering...) that using lots of Adell clamps placed pretty close together would reduce and damp vibration. the big-buck solution is AN-32 braided-steel line but i don't think very many people take that path. fewer after pricing it first :-) ... |
tryan |
saden and nippondennso compressors are mucho smaller than that york piston pump. you might not have to notch if you can modify the mount to get the compressor closer to the motor.
ein 6er |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,115 Joined: 11-February 03 Member No.: 300 Region Association: None ![]() |
i have seen a foto of a 6 with a/c and the firewall was not cut. but i don't know what type of compressor it was.
Steve |
The biggest problem with an air conditioned six is the AC compressor pulley on the crank.
The second belt is way to far forward. I have heard of people using the non airconditioned pulley and using one belt to drive the compressor and fan. I have not seen any pictures or details. Steve |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Steve.. what about the single belt serpentine conversion ??
The car I'm doing it on is a factory six.. I'll know in a few weeks whether or not it clears everything. Thanks for the pics Jim !! And ..yes .. If I have to I'll go to a Suzuki Samari style compressor (real tiny) but is effecient enough to cool a 914 cabin (to keep from notching the firewall) B |
Brad Roberts |
Steve..
what about running it off one of the camshaft ala powersteering pump for 3.6 ?? Interesting thought... B |
ChrisReale |
Sleazy ![]() ![]() ![]() ![]() Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 ![]() |
Just roll the windows down and save yourself the headache (IMG:style_emoticons/default/laugh.gif) Although, when I was driving back from a Portland AX and it was anoput 98 degrees out, and I had two hot VRacers on the passenger side seat, AC woulda been proper
Brad Roberts |
When your 45-50 years old and have 70k to drop on a 914... you'll want AC.
B |
ChrisReale |
QUOTE(Brad Roberts @ Aug 29 2003, 11:23 PM) When your 45-50 years old and have 70k to drop on a 914... you'll want AC. B Good point (IMG:style_emoticons/default/ohmy.gif) |
Mike9142.0 |
Member ![]() ![]() Group: Members Posts: 219 Joined: 29-January 03 From: Phoenix, AZ Member No.: 208 Region Association: Southwest Region ![]() |
A/C off the cam? That sounds like a lot of load for the cam when the clutch locks in.
Brad Roberts |
Actually Mike... these high effiency compressors barely draw 4-5 HP (unlike the old one pictured that robbed 8-10hp) It was just a thought.. I know the power steering pumps carry a decent load (they have to pump fluid 13 feet to and from the front of a 993). I wouldnt swear to it.. but I think the 3.6 has a extra bearing or some kind of extra support for the power steering pump.
B |
Lo-Fi Version | Time is now: 30th June 2024 - 12:53 PM |
