Shall I say... 3.6?, my conversion thread ... |
Jan 22 2006, 10:50 PM
Resident German Group: Admin Posts: 41,891 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
and here's the new stuff, bling bling ... (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif)
250lbs springs on threaded collars, adjustable perches: (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif) Attached image(s) |
Scott Carlberg |
Porsche MOTORSPORTS Group: Members Posts: 1,595 Joined: 17-April 03 From: Modesto, Ca Member No.: 580 |
DAMN Andy, er, SirAndy,
planning on going to the TRACK sometime soon?? (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/clap56.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) |
Jan 22 2006, 10:56 PM
we had some fitting problems on the bilstein shocks. the problem was that the top aluminum spring plate is obviously designed to work with koni shocks.
the center hole for the shockshaft was too small and the top of the plate has a ~1/8 "hump" that will result in not enough thread to secure the nut on top if you use the stock rubber pieces. we found a workable solution by cutting off about 1/8 of the top mounting piece that is usually screwed on the shaft and holds the lower rubber spacer. then, we took off the same amount (~1/8) off the top rubber and voila! we got enough thread to fasten the top nut! here is mark honing out the center hole, using his "special precision" shop equipment: (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Attached image(s) |
Jan 22 2006, 10:57 PM
this shows how much of the top rubber needs to be cut off:
Jan 22 2006, 10:58 PM
here you can see the part of the top mounting piece that still needs to be cut off to be level with the rubber:
Jan 22 2006, 10:59 PM
and done (sans the top rubber):
Jan 22 2006, 11:00 PM
perfect fit! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) (with new sway bar hooked up):
redshift |
Jan 22 2006, 11:02 PM
artsy shot of mark posing ... (IMG:http://www.914world.com/bbs2/html/emoticons/gayfight.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
redshift |
Jan 22 2006, 11:03 PM
Jan 22 2006, 11:05 PM
last for today, butt shot after adjusting the ride height ...
5" in the front, from bottom edge of floor pan 5 1/2" in the rear, from bottom edge of floor pan trekkor took a quick ride around the block with me, the 250lbs springs feel great! better actually than my old 180lbs. (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) i'm happy! (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/givemebeer.gif) Andy Attached image(s) |
Jan 22 2006, 11:08 PM
no way! trek is a monster! (IMG:http://www.914world.com/bbs2/html/emoticons/burnout.gif) |
rick 918-S |
Jan 22 2006, 11:36 PM
Hey nice rack! -Celette Group: Members Posts: 20,785 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Root_Werks |
Jan 23 2006, 10:29 AM
Village Idiot Group: Members Posts: 8,484 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Jan 28 2006, 11:07 PM
some more babysteps today ...
mark and i scratched our heads long and hard (mine was easier cuz i don't have nearly as much hair as he does) and we came up with a concept for the front mounted oil cooler and the "out the hood" venting of the hot air ... first, i'd like to mention again that i "hate", yes hate, the idea of dumping any significant amount of additional air under the car. (IMG:http://www.914world.com/bbs2/html/emoticons/icon8.gif) i don't care if that's how the factory did it. their solution was quick & dirty as they were planning on racing the GTs in '70. they obviously did what got them results quick and without too much work. additional air under the car *will* create additional lift, especially at higher speeds. soooooo, i'm opting for a "out the top" solution. but i also hate those big ass holes in the hood, so i'm going for a more stealth approach. louvers! here's a vinyl mockup of where the louvers will be, once painted in body color, they'll be hardly noticeable, but *very* effective! (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) Attached image(s) |
one more ...
Jan 28 2006, 11:10 PM
we also made a cardboard mockup of the oil-cooler and used a small metal rod to mock up the curvature of the air-channel (see green arrows) ...
it'll be a nice and smooth curvature and should give me a good airflow ... (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) Attached image(s) |
Jan 28 2006, 11:12 PM
hopefully, by next weekend, i'll have the cooler and the aluminium panels for the channel/shroud ...
cutting the hood will be fun! (IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/beer3.gif) |
Aaron Cox |
Jan 28 2006, 11:22 PM
i have similat bilsein coilover issues. looks like you sorted it out prtty well.
rock! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
Jeroen |
Jan 28 2006, 11:32 PM
I just remembered I promised to measure that front x-member
It's 81,5 cm Been thinking about louvres too... I like this look: (IMG:http://www.motonsuspension.com/afbeeldingen/251.jpg) Sure would looks nicer than a big-ass-gaping-hole (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Lo-Fi Version | Time is now: 24th November 2024 - 10:26 AM |
