ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
Here's the head being drilled.
Attached image(s) ![]() |
ChrisFoley |
The block is ready for the top end assembly.
ChrisFoley |
I think I have everything clean and ready, so here goes!
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
Are all those pully's and angles for the belt inefficient?
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,126 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
chris, got a picture of your carb linkage installed? what's the brand? looks pretty stout.
kevin |
ChrisFoley |
QUOTE(seanery @ Sep 7 2003, 01:30 PM) Are all those pully's and angles for the belt inefficient? nope. |
ChrisFoley |
Assembly complete. Installation tomorrow. Dyno Tuesday.
ChrisFoley |
QUOTE(rhodyguy @ Sep 7 2003, 02:00 PM) chris, got a picture of your carb linkage installed? what's the brand? looks pretty stout. kevin The linkage was purchased with a set of 40IDFs back in the '80s by my brother Charley. It came from Red Lion in CA. (don't think they are around anymore) |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
(IMG:style_emoticons/default/confused24.gif) red lion? could it have been red-line? red line is like the west coast weber distributor
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Chris.. dont mean to be a nit pick.. but you dont *really* run rubber tranny mounts do you ??
B |
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
Man! It's cool! That looks cool!
M |
ChrisFoley |
QUOTE(Brad Roberts @ Sep 8 2003, 02:17 AM) Chris.. dont mean to be a nit pick.. but you dont *really* run rubber tranny mounts do you ?? B I switched back to them after getting pissed for the last time at the POS Weltmeister solid mounts. The front motor mounts are aluminum blocks. I might have a pair of 911 (914 sport) mounts somewhere. I'm not comfortable with the thought of solid mounts at both ends. (Maybe I should just get over it.) Aaron, yes it was red Lion. I think they advertised in VW and Porsche magazine back in those days. |
ChrisFoley |
QUOTE(redshift @ Sep 8 2003, 02:40 AM) Man! It's cool! That looks cool! M Thanks! It had better go like stink too, or I'm gonna be very depressed. |
Brad Roberts |
I gotcha. The Weltmeister plastic crap does suck (they compress too esily). We run aluminum blocks.
Man.. that fan shroud looks COOL. I'm a little concerned that you dont have enough crank case ventilation. Every EP/FP car I have seen has a huge radiator style hose going into the top of the block and into a breather box mounted in the trunk. B |
ChrisFoley |
QUOTE(Brad Roberts @ Sep 8 2003, 11:37 AM) I'm a little concerned that you dont have enough crank case ventilation. There's a 3/4"id hose from both valve covers and a -10an line from the top of the case. They all go into a custom aluminum box filled with fuel cell foam in the trunk that has a breather element on top. There's never any oil residue in the trunk. Also the dry sump pump helps pull pressure out of the case. The an line from the top of the case is also an automatic drain back feature. My plan is to run a 3 stage external pump to pull on the valve covers and scavenge the case, and switch back to a single stage pump in the stock location. |
ChrisFoley |
Here's a pic of the breather tank
ChrisFoley |
and the return line.
ChrisFoley |
IT RUNS!
I timed it to 33 deg total advance. I don't know much about the Mallory distributor yet so I'll probably have to fiddle with it a bit more. |
Brad Roberts |
Great NEWS Chris (IMG:style_emoticons/default/clap56.gif) I only noticed one -10 line at the oil filler area...thanks for clearing that up for me. You nailed the hot ticket.. use the scavenge from the dry sump setup to pull a vacuum on the engine.
B |
campbellcj |
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,557 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California ![]() ![]() |
Looks sweet Chris! Almost makes me miss the Type4 (almost...nah) (IMG:style_emoticons/default/wink.gif)
So where does one get truly solid trans mounts i.e. the alloy blocks? I was appalled when I ordered "solid" mounts and received these Welt things which are chunks of urethane or something. |
Lo-Fi Version | Time is now: 4th July 2024 - 01:25 PM |
