restoring?, more like preserving, actually... |
rjames |
Jan 25 2006, 01:18 PM
I'm made of metal Group: Members Posts: 4,002 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Rust near jack point... Do I bother welding in new piece, or just cut it out and leave the holes? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) I was thinking about cutting off the jack tubes anyway.
rjames |
Jan 25 2006, 01:20 PM
Small rust hole...(this is after attacking it with a screwdriver...)
rjames |
Jan 25 2006, 01:25 PM
Other then the couple of holes I've pointed out in the pictures, they look pretty good. You can see however that there's a consistent line of rust along the top seam that runs the length of the rocker panel.
I will be grinding that down, but worry if this was a weld bead or something that will need to be re-welded? Does it hold 'things together' at all? It runs the entire length of the long. |
rjames |
Jan 25 2006, 01:27 PM
Well at least I can repot the plants in the house with all of the dirt that came out when removing the rocker panel cover...
snflupigus |
Jan 25 2006, 09:56 PM
Member Group: Members Posts: 320 Joined: 29-May 05 From: Gilbert, AZ Member No.: 4,163 Region Association: None |
amazing similarities with your pics and mine LOL... I'll put more of mine up tonight. I also busted off all but 2 rocker screws. Had to use vice grips and snapped em off.
snflupigus |
Jan 26 2006, 01:38 AM
http://www.snflupigus.com/914issues/914issues.htm
my update... dont worry you're not far away. it takes less time than you think. |
Lo-Fi Version | Time is now: 29th June 2024 - 01:29 AM |
