dan10101 |
TORQUE-o-holic ![]() ![]() ![]() Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest ![]() |
Here's a cross section of a caliper for someone who was wondering what it looks like. Well, at least I was.. (IMG:style_emoticons/default/rolleyes.gif)
Attached image(s) ![]() |
MarkV |
Fear the Jack Stands ![]() ![]() ![]() Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None ![]() |
That looks like a lot of effort. Did you try compressed air? You could have wrapped a rag around it hooked it up to the car & pumped the brakes. (IMG:style_emoticons/default/cool_shades.gif)
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
130psi did nothing. we did that for a day (seriously) and only one piston out.. Acutally not much work. maybe 10 mins each (sawing)...
We got them out and im happy.. car WILL run sunday. I guarantee it (IMG:style_emoticons/default/wink.gif) |
dan10101 |
Tried everything. Eventually would have gotten them out, just got tired and frustrated.
Didn't try on the car, the brakes weren't even close to applying pressure. We would have had to install old calipers and bleed the entire system before we'd have any brake pressure. Plus the seals around the pistons were leaking air. It would move a bit from the compressor, then we would push it back in and try again. Each time it moved a bit more. It's actually quite easy to cut in half. But, it kinda ruins the calipers. (IMG:style_emoticons/default/ar15.gif) |
dan10101 |
hey go to bed! (IMG:style_emoticons/default/Yack.gif)
Andyrew |
But, "I feel like dancin, ya ya ya"
(IMG:style_emoticons/default/dance.gif) Fine (IMG:style_emoticons/default/sad2.gif) |
MarkV |
I agree, it's a school night. (IMG:style_emoticons/default/laugh.gif)
Andyrew |
Alright, everything is ready to roll (except the brakes, will do tonight..), so we tryed to start it.. well at first it wouldnt turn over, period. checked some things, then dad found something not put in all the way. Next it turns over, but know it doesnt fire, and I dont hear the fuel pump, and it looks like it leaked ( (IMG:style_emoticons/default/headbang.gif) ), so we checked for spark and the wires arnt getting any spark, what things should we check for troubleshooting?
Anything helps, Andrew |
Andyrew |
Alright, maybe your stumped.. heres some more info, We have been trying the fuel pump, and we dont seem to be getting any power to the pump. Any clues?
Thanks Andrew |
dan10101 |
Ok, jumping the fuel pump relay, we get 12 volts to the pump, but no action out of the pump. Plus the pump is seeping fuel.
Still troubleshooting... (IMG:style_emoticons/default/smash.gif) |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
With power to the pump.. tap on it with the end of a screw driver. They can get gummed up when they sit for too long. Dont worry about the seeping fuel right now.. the seals are probably dry and will need to have gas on them for awhile. You might get lucky and have the pump come back to life.
B |
Brad Roberts |
Oh.. check your ground at the pump. Make sure you have continuity to the ground on the battery (easy to do with the battery above it).
B |
Andyrew |
The ground is from the big cluster of grounds by the relay board right? I think I have a good ground on that, I'll double check.
QUOTE With power to the pump.. tap on it with the end of a screw driver. They can get gummed up when they sit for too long. Dont worry about the seeping fuel right now.. the seals are probably dry and will need to have gas on them for awhile. You might get lucky and have the pump come back to life. I will try this, but I am also thinking of taking the fuel pump out and taking it apart, any reason or referance for doing this? Are they rebuildable? Thanks Andrew (IMG:style_emoticons/default/wavey.gif) |
ChrisReale |
Sleazy ![]() ![]() ![]() ![]() Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 ![]() |
I think fuel pumps are rebuildable, but I seem to recall one of the gaskets is hard to come by. I might be wrong. It would probably be worth your time to find a good used one..
Andyrew |
I just picked up another fuel pump, dont know if it works, but its a just in case thing.. I'll try getting the one I have on there now working, if not, I'll open it up and try and swich good parts for bad...
Does anyone know of a tech article for rebuilding it? I have heard of one, and I didnt see it in the tech places I looked at.. Thanks Andrew |
Andyrew |
Alright, fixed the fuel pump (temporarily) and the pump was good, the wires, no..
Now it doesnt have spark.. It has spark from the coil, but not from the Dizzy.. New cap, new rotor. Electronic ignition.. Any ideas? I really want this thing on the road tonight.. Thanks Andrew |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Put points in it to get it running. Keep it simple
Geoff |
Andyrew |
Thanks, I did that, but it seemed to be that the wire attaching the coil to the dizzy wasnt in completely on the coil side (we found this after we changed points) And it now has fuel, and has spark.. So we'll do the timing next.. I think we almost have it.. Brakes bleed, pedal feels good. umm the drivers harness is installed, I think im going to need a harness bar, the shoulder one is not taunt, and the seat is holding my shoulders, so thats going to be fixed, later.
Andrew Needing to drive, not wanting, needing (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/sad2.gif) |
dan10101 |
Monster Garage Day.. (IMG:style_emoticons/default/idea.gif) .. 15....
IT RUNS!!! Andrew no longer NEEDs to drive the Teener. Now he just want's to drive it more. Here's where we are at. We ran new wires to the fuel pump. Direct to the battery. It works. Then we started playing with the ignition. I must have tried setting it to TDC 3 or 4 times before I finally got it right. WAY out of practice. Heck, I was doing this 30 years ago when I was Andrews age. Anyway after we were almost ready to back it out of the garage and put it up on blocks, it finally started. We checked dwell and set the timing. Beat on the fenders a bit to make the 225x16 tires roll. And took it on it's maiden voyage. Hey, we even got it home without calling a tow truck. (IMG:style_emoticons/default/dance.gif) But, we're not done. Here's just the ones I can think of..
Brad Roberts |
Congrats gang !! (IMG:style_emoticons/default/clap56.gif) (IMG:style_emoticons/default/clap56.gif) (IMG:style_emoticons/default/clap56.gif) Andrew.. I'll buy your dad a beer the next time I see him.
B |
Lo-Fi Version | Time is now: 7th July 2024 - 06:14 AM |
