biosurfer1 |
Teener fo Life! ![]() ![]() ![]() ![]() Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California ![]() |
roughly, how many gallons should the 914 hold, i put about 8 gallons in when the pump stopped but the gauge says i only have about half a tank, checking to see if its the guage or the pump....thanks
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,373 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
A little over 16 if I remember right.
Paul |
MarkV |
Fear the Jack Stands ![]() ![]() ![]() Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None ![]() |
16.4 US gallons.
ChrisReale |
Sleazy ![]() ![]() ![]() ![]() Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 ![]() |
I think around 12 gallons...maybe??
Qarl |
Shriveled member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None ![]() ![]() |
Don't put the filler nozzle all the way down.
biosurfer1 |
sounds like its the pump...huh, wonder why it shut off so soon...thanks guys
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
see Karl's post.
You can't put it in all the way cause the auto shut off holes are into the tank's fuel and will stop. You kinda have to hold it up. |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
yeah ive figure that out too. i cant ever get more than 14 or so in my car! and thats up to the rim of the tank- i even ran out of gas and i got like 15 in and thats it!
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Today's gas pumps are made for cars that have a filler neck going down a ways to get to the tank. The 914 fills directly into the tank, and the tank itself is relatively wide and flat. Let the pump click off, then pull the nozzle most of the way out of the tank. Fill it the rest of the way until you can see fuel in the filler neck. Then, if you're really anal, you can wiggle the car to "burp" air bubbles out the filler. And put more gas in...
I've put just under 16 gallons in--once. --DD |
Lo-Fi Version | Time is now: 30th June 2024 - 12:45 PM |
