Qarl |
Shriveled member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None ![]() ![]() |
Does anyone know what is significantly or fundamentally different about main body wiring harnesses from 1974 to 1975.
The engine harness doesn't count. What's different? Thanks! |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,416 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
Is there a prize involved?
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,582 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Guesses:
1. The 75 harness would not have the 'Fasten Seatbelt' wiring as in the 74 harness? 2. The 75 Catalytic converter cars (California only?) would have wiring for the cat and dash light...the 74 would not. |
Qarl |
My '75 has the fasten seatbelt light.
And no cat dash light. |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
so does mine
Qarl |
But I do have the wiring for the EGR counter under the passenger foot rest.
Qarl |
What about the ignition switch? I know the '75 and '76 cars used a VW Rabbit ignition switch. Are the connectors different?
scotty |
The Fun Never Stops ![]() ![]() ![]() Group: Members Posts: 773 Joined: 20-May 03 From: Portland. Oregon (SW) Member No.: 718 Region Association: None ![]() |
My early 75 had the same wiring harness as a 74 as far as I could tell... including that stupid seatbelt interlock crap (IMG:style_emoticons/default/mad.gif)
Which part's giving you trouble, Karl? |
TheCabinetmaker |
The connections are the the same. I've put the rabbit switch in a 73 and a 74. It's also about 1/4 the price!
Qarl |
Our good friend George says the '75/'76 harnesses are "significantly different" than the earlier harnesses.
Other than the EGR wiring and the seatbelt buzzer crap (also on '74s), I fail to see what is different between a '74 and '75 main chassis harness. Yes... maybe the wiring order is different, but could you effectively install a '74 harness in your '75 car and have everything work? Everything that plugs into the harness (light housings, switches, door sensors, brake switches, fuel fillers, gauges, is the same). Since I'm not using the relay board, what's the real difference then?... Hmmm???? |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
I thought the wiper switches were different? maybe not..
I don't see what could go wrong with using a 74 harness. Geoff |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,714 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
QUOTE(kellzey @ Sep 3 2003, 02:09 PM) Yes... maybe the wiring order is different, but could you effectively install a '74 harness in your '75 car and have everything work? i put a '73 harness in a '70 car and it works great, just needed quite a bit of (IMG:style_emoticons/default/smash.gif) soooo, '74 to '75 should be no problem at all ... Andy |
Lo-Fi Version | Time is now: 2nd July 2024 - 10:16 AM |
