GaroldShaffer |
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None ![]() ![]() ![]() |
OK, dum question. My tires came in today from the Tire Rack (IMG:style_emoticons/default/clap56.gif) . So it is now time to
get them mounted and balanced. I have a nice set of Fuch's I want them on but I don't want the weights to spoil the looks of the Fuchs. Can the weights be mounted to the back side of the rim so not to be seen? I really never gave it much tought in the past with my thruck when I got new tires, its a truck. OK there is my dumb question for today. - Garold |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Yes, the weights can be mounted on the farside of the wheel, that is how I have mine done on all my cars (and the truck)
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
QUOTE(itsa914 @ Sep 2 2003, 11:51 AM) Can the weights be mounted to the back side of the rim so not to be seen? more likely - or as likely - they will use stick-on weights on the inside of the rim. i just had a set done and they wanted me to sign a waiver that they wouldn't be responsible for stick-on weights coming off - so naturally, it was one of their clip-ons that was lying loose at the bottom of the stock when i loaded them into the car ... racer guys will carefully run a piece of racer's (duct) tape to any stick-on weights -- the heat from track use can loosen the adhesive in the tape ... i doubt this would last many seasons of street use but it couldn't hurt ... if you won't let them stick a weight where it's needed it may require much more weight somewhere else - and it may not be possible to balance at all. fortunately - contemporary tires require far fewer balance weights than the olden tymes ... |
Lo-Fi Version | Time is now: 30th June 2024 - 01:01 PM |
