Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
As it says above, does the original 2.0 914/6 use leaded fuel or is unleaded ok? The book says 98 octain but it doesn't say anything about Leaded or Unleaded. My 74 had an Unleaded Only sticker but the 6 doesn't!
Jeff |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
QUOTE(Jeffs74~914 @ Sep 2 2003, 04:30 PM) As it says above, does the original 2.0 914/6 use leaded fuel or is unleaded ok? The book says 98 octane but it doesn't say anything about Leaded or Unleaded. My 74 had an Unleaded Only sticker but the 6 doesn't! the original 914.6 used leaded fuel because that's all there was in 1970 unless you were in one of the rare areas where Amoco 100 Clear was available. (i wasn't). it is required in catalytic convertor cars, and possibly it's recommended for thermal reactor cars too; i don't know if your '74 is a cat car or not. (911's were, lots of other cars were too - but some weren't. BMW tried for a long time to get by with thermal reactors and avoid the unleaded requirement - and those last few cars were dogs...) it was an issue for American muscle cars that were trying to run valve seats directly in their cast-iron heads. aircooled cars have always run very hard valve seat inserts and are unaffected by the absense of lead - usually, they're better off without it. BTW - that 98 number was a Research number; it's approximately equivalent to the 92-94 "AntiKnock Index" Research-Motor average posted for conventional unleaded premium. |
Jeffs9146 |
OK so if I am hearing you right; Unleaded is ok and Octane Booster would help get the 92-94 numbers!
Thanks for the info! (IMG:style_emoticons/default/clap56.gif) Jeff |
sixerdon |
Member ![]() ![]() Group: Members Posts: 466 Joined: 23-May 03 From: Dartmouth, MA Member No.: 731 ![]() |
You got it Rich. Those were the good old days when they used to call it "High Test" and there used to be an oval sticker on the expansion tank. Gas used to smell a lot different then than it does now. A good drag on the fumes would make you smile and would give you the posted times you read in those old articles!
Everyone with 914's be it 4 or 6 cyl. should take care of what information is useful in the owners manuals. A lot of the information is obsolete. Don |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,416 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
Therefore Rich you are old enough to remember leaded gas and others here have never heard of it. (IMG:style_emoticons/default/lol3.gif)
Sorry Paul |
ArtechnikA |
QUOTE(Jeffs74~914 @ Sep 2 2003, 04:55 PM) OK so if I am hearing you right; Unleaded is ok and Octane Booster would help get the 92-94 numbers! except that you can't possibly add enough Octane Booster to get those numbers - just run pump premium - it'll be fine. you gotta read the fine print on the octane booster label - when they talk about raising the octane rating "4 points" they mean from 92 to 92.4 just run pump premium unleaded. |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Jeff, if ya want 93 octane ya gotta move to Oklahoma!
ArtechnikA |
QUOTE(URY914 @ Sep 2 2003, 04:57 PM) Therefore Rich you are old enough to remember leaded gas and others here have never heard of it. Sorry no need to be sorry, i neither advertise nor conceal that i am the same age as my '53 356 1500N Coupe; for the arithmetically challenged, that means i'm 50. most days i don't feel it; some days i can feel it creeping up on me... oh - i MIGHT also have heard of leaded gas in flight school where we learned 100LL is the blue stuff called for in the POH (Pilot's Operating Handbook) ... |
ArtechnikA |
QUOTE(vsg914 @ Sep 2 2003, 05:03 PM) Jeff, if ya want 93 octane ya gotta move to Oklahoma! local Sunoco stations here in PA have 94 ... interestingly, there's a section on octane in the Bosch MFI book (spent a lot of time with that this weekend getting my idle mixture and 6 airflows balanced...) that mentions that starting with the 2,4 MFI engines 87 Octane is specified, and due to the slower burn rate of higher octane fuels, runnign higher octane fuel can result in excessive CO levels. just a thought for those 'more is better' discussions - especially for anyone having trouble getting a car though an emissions test ... |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
QUOTE Therefore Rich you are old enough to remember leaded gas and others here have never heard of it. Leaded? Whats that? jk.. actually I learned it when my dad got his car, that was the turning from dork to p-car freek. (IMG:style_emoticons/default/laugh.gif) Andrew |
Jeffs9146 |
QUOTE Jeff, if ya want 93 octane ya gotta move to Oklahoma! I think I will stay in California, thanks! QUOTE when they talk about raising the octane rating "4 points" they mean from 92 to 92.4 OK, no lead and no boost!! Cheaper is better!! It won't matter when I get the 3.2L! Jeff |
mikester |
Member ![]() ![]() Group: Members Posts: 326 Joined: 18-June 03 From: CA Member No.: 837 ![]() |
Just a note, check the method used to calculate the octane rating.
The octane rating is ROZ/RON where as pump octane is calculated as (R+M)/2. The label inside my porsche shows the method used; with a 91 as the number. The factory sticker is for RON only where as pump octane is an average of RON and MON ((R+M)/2). If your engine is not stock and of higher compression or not properly cooled and running warm then more octane may be required but a stock engine (4 cylinder, I don't have a six so I don't know sixes) with proper cooling shouldn't require any a higher than 87 octane rating. If you've got the european domed pistons, your compression ratio is higher, thus it may require higher octane to reduce preignition. Octane does not prevent the fuel from burning per say, it prevents uncontrolled burning. With proper compression, cooling and timing you won't have to waste money on higher octane to get the proper performance from your engine. |
ArtechnikA |
QUOTE(mikester @ Sep 2 2003, 06:13 PM) European is ROZ/RON where as American is (R+M)/2. ... a stock engine (4 cylinder, I don't have a six so I don't know sixes) shouldn't require any a higher than 87 octane rating. "ROZ / RON" is not a method, it's just bilingual -- Research Octane Zeitung / Research Octane Number (same thing...). don't know what method the Europeans are using today (Jeroen ?) but the Research number was typically used in the early 70's -- it tends to produce a higher number for the same fuel and therefore the petroleum companiues liked it -- but the auto industry and "consumer groups" claimed the Motor number was closer to what an operating engine actually required. as a compromise, the number you now see posted is the average of the Motor and Research numbers. this change was mandated by Fedral law somewhere in the early 80's IIRC. 1,7's had a slightly higher static compression ratio and can use midgrade. the /6 owner's manual calls for premium. "should" it need it ? maybe not, and i don't recall any pre-ignition issues, but i'm not risking it nowadays with the 911 ... |
mikester |
Yeah, I went back to my reading and edited my post accordingly. I'd say that more recent engines probably do require a higher octane - I'm simple stating the research I did with my little a$$ 1.8L. With the recent rise in gas prices and the knowledge of what octane was I came to these conclusions via some research on the net...
I didn't agree with all of it of course... |
drew365 |
These are the good old days! ![]() ![]() ![]() ![]() Group: Members Posts: 2,004 Joined: 29-December 02 From: Sunny So. Cal. Member No.: 37 ![]() |
QUOTE when they talk about raising the octane rating "4 points" they mean from 92 to 92.4 My car has 11.5:1 Mahle pistons. When I'm on the track I run 110 race gas, but when I drive on the street I use premium with booster. So I'm not really gaining much by using the booster. Luckily I don't drive on the street very much. |
ArtechnikA |
QUOTE(drew365 @ Sep 3 2003, 07:17 AM) My car has 11.5:1 Mahle pistons. When I'm on the track I run 110 race gas, but when I drive on the street I use premium with booster. So I'm not really gaining much by using the booster. Luckily I don't drive on the street very much. yes, that's your static compression - but i bet you also have high-lift, high-overlap cams to take advantage of that compression at higher rpm. so considering all the charge leakage at lower revs, you actual dynamic compression could be pretty reasonable. if octane booster is the difference between pinging and not, go for it - just one shouldn't be expecting miracles - and the sellers would like you to believe "4 points" means increasing from 92 to 96 but it doesn't. there's also diminishing returns, because higher-octane pump gas is more likely to already contain some of the chemical goodies in the booster stuff - and you don't get a linear percentage gain. in olden tymes, we used to mix premium leaded and unleaded to take advantage of this effect -- adding just a little bit of tetraethyl lead to already premium unleaded raised its AKI a lot more than the same amount would increase the AKI of leaded gas. i have also had to clean the orange manganese fouling from plugs after trying to run too much over-the-counter octane booster - wasn't worth it... |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,002 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
QUOTE(Jeffs74~914 @ Sep 2 2003, 04:30 PM) My 74 had an Unleaded Only sticker but the 6 doesn't! Are you sure your 74 wasn't really a CA-spec 75? Unleaded is only required by cars with catalytic converters, and 74s did not come with them. I haven't seen a 74 with that sticker so far, just some 75s and 76es. To reiterate, unleaded fuel is just fine for any and all 914s. None of them ever required lead in the fuel. Oh, the difference between the RON and MON ratings of a given batch of gasoline is called that fuel's "sensitivity". RON is generally 8-10 full numbers higher than MON for the exact same fuel, so US pump octane ratings (average of RON and MON) will typically be 4-5 numbers lower than the RON (or ROZ, same thing in German) numbers listed in the owner's manual. --DD |
Jeffs9146 |
I think the OP had replace the tank when he rebuilt the motor! That must be the reason for the sticker!
Jeff |
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
QUOTE(ArtechnikA @ Sep 2 2003, 09:07 PM) local Sunoco stations here in PA have 94 ... Over near Stone Mountain, there is a place you can buy 114, it's a chain too, and it smells like the high test Mr. Carrol used to pump into my grandmaw's '67 Plymouth VIP... ..she used to say, "Fill 'er up!", and he'd say, "Check the oil, Mizzzzz Dixie?".. "Yep." Self Serve... PATOOOOOOIE! If I run anything higher than 87 (local?) in a stock 2.0/4, it runs very cold, too cold. M |
Nemo914 |
Member ![]() ![]() Group: Members Posts: 76 Joined: 11-July 03 From: Cape Cod, MA Member No.: 902 ![]() |
Wow, learned a lot on this thread. Here is an observation--I was having backfire/sputter problems on deceleration with my stock 72 1.7. I tried everything to fix it, including replacing the exhaust system. Then I had a thought that the problem started when I started using high octane gas. I switched back to 87 and the problem seems to have gone away?? Could this really have been my problem all along?
Lo-Fi Version | Time is now: 2nd July 2024 - 10:18 AM |
