Only 32k miles, but stored for 20 years..., How far should I take the Engine apart? |
dsmeyer |
Feb 9 2006, 09:55 AM
'73 914 2.0 Group: Members Posts: 134 Joined: 30-September 03 From: West Michigan Member No.: 1,210 |
My project is a bone stock 914 2.0 that was stored for almost 20 years.
The Silver paint is bad but it has only minor surface rust on the battery tray and a couple other spots. I have stripped the car completely for paint work and plan to restore and, or rebuild everything before it goes back on the car. My question is, how far should I take the Engine and Transmission apart? The Engine turns over freely by hand. I would like a McMark Engine, but I would also like to keep the stock fuel injection. Maybe 1/2 a McMark Engine with stock fuel injection. Would it be worth it? 1/2 meaning I may only get half the power increase with stock fuel injection. My old 150k 2.0 is stock other than "Euro" flat top pistons and was great for many, many years, but a little extra power would be nice. The least I would do is take it down to the short block and just replace the pistons and cylinders and rebuild the heads if needed. The most I would do is McMark engine with stock fuel injection. I would really like to hear what the Engine Experts on this forum would recommend. As for the Transmission, should I just change the oil and run it, or take it apart and give it a good cleaning and inspection inside? |
SLITS |
Feb 9 2006, 10:02 AM
If the engine turns 360 degrees.....fire it up and see what it does. Why take it apart if there's nothing wrong?
tat2dphreak |
Feb 9 2006, 10:10 AM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) be sure and run clean gas through and let 'er rip! if it breaks THEN rebuild (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
dsmeyer |
Feb 9 2006, 11:24 AM
Thanks for the replies, but "try it, and see what happens" is not an option. The engine is already out and the inside of the fuel tank looked like resent photos of the Titanic. The previous owner said that he had filled the tank before storage, but only about 6 or 7 gallons of toxic goo drained out. |
Porsche Rescue |
Feb 9 2006, 11:35 AM
I am not an engine expert, but if it only has 32K on it I would not tear it down. Clean the fuel system, bench clean and test the injectors (9V battery will do it), replace the fuel hoses and install. You might do some sort of flush with light oil/solvent of some sort while engine is out. Adjust valves, install and start. If it is bad, it is not a big deal to remove it and tear down.
Lo-Fi Version | Time is now: 2nd January 2025 - 09:25 PM |
