Under car work, alunimum cover over the shift linkage |
Randal |
Sep 3 2003, 02:24 PM
I managed to break my little aluminum plate(?) that the black plastic cover attaches to under the transmission. I bought a new aluminum plate that I now want to install.
I did get all new "O" rings and such and will be careful to put them back in the way they came out. But... in order to get the black plastic cover off I have to remove the pin that holds the shifting mechanism. I thought this was just a simple "punch out" kind of operation, but now I'm concerned about making sure it goes back exactly the same way it came out. It would be fun to do this only once! Looking for advice. Thanks in advance. |
Brad Roberts |
Sep 3 2003, 02:26 PM
Um.. Randal. The shift linkage UNBOLTS. There are NO pins that you need to remove. Remove the allen set screw in the front coupler and the rear coupler and the bar slides out and your plastic cover comes off. Oh.. make sure you drain the trann fluid before pulling the shift console down << proper term for the part your talking about.
B |
Brad Roberts |
Sep 3 2003, 02:30 PM
Oh wait.. Typically you would buy a good used shift console complete. Did you "really" buy a new one that is bare with no shaft thru it or seals in it ??
I'll find a pic in a minute. B |
porsche735 |
Sep 3 2003, 02:33 PM
Member Group: Members Posts: 189 Joined: 10-January 03 From: Los Altos, CA Member No.: 127 |
Just mark the direction of the lever so you don't put it on backwards. It is easy to do. Beware of all the fluid coming out! Make sure you drain the tranny first.
Chris |
Brad Roberts |
Sep 3 2003, 02:39 PM
Here we go.. lets use this pic to see if we can figure out what part he bought.
B |
Brad Roberts |
Sep 3 2003, 02:40 PM
I really need to have a class on how to do screen shots of the PET and post them here. It would make life much easier.
Randal, how much did a new one run ?? (I'm afraid to ask). B |
Randal |
Sep 3 2003, 02:53 PM
I bought the shift consol from HPP, with all the seals, etc. for $60.00.
So the only things I have to take off are part number 19 (thanks for the picture), which is an Allen screw and course the bolts. Thanks for the advice about the oil. That would have been a surprise! |
Brad Roberts |
Sep 3 2003, 02:56 PM
Part 19 IS a roll pin. You can do this on the bench when you get it off the car. Take a digital pic of it onec you get it out of the car so you can reference the pic when going back together with the new one.
It comes as NO surprise that Rich wouldnt sell you a good used one COMPLETE that you could bolt into the car in about 10 minutes. What a pain in the ass (not him).. replacing all the parts. B |
Randal |
Sep 3 2003, 03:40 PM
Oh, this is what I bought.
Brad Roberts |
Sep 3 2003, 03:43 PM
I understand now.
B |
Randal |
Sep 3 2003, 04:45 PM
Are you saying that Rick put together a complete assembly to make it easier to bolt in?
By assembly I mean the seal at the bottom of the shaft and the poly bushing. Or maybe it comes apart even more than that. |
Sep 3 2003, 05:29 PM
Custom Member Group: Members Posts: 24,599 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I broke part 14, just the rear tooth. (IMG:style_emoticons/default/mad.gif)
Lo-Fi Version | Time is now: 2nd July 2024 - 10:17 AM |
