Rockaria |
ZippidyDoDah... ![]() ![]() ![]() Group: Members Posts: 817 Joined: 2-May 03 From: Southwest, USA Member No.: 645 Region Association: None ![]() |
Hello Everyone,
First off my car runs (seems to run) perfectly. A few months ago I did a spark plug test and all 4 plugs looked exactly the same (Just a little dry black soot) meaning to me a little rich, and just the way I wanted it. As the summer came and is going I started to notice my #2 getting cooler than the #4. At times a difference as much as 60 degrees. I put it as hot weather and the oil cooler on the #4 side. But I recently checked the plugs again and have noticed that #1 and #3 are just like they always have been, but #2 is runing richer than normal and #4 is running leaner than normal. Any off the hip ideas? I put in a new Fuel injector on #2 thinking that maybe it was old and gunked up and open. But the new injector runs just as rich. Like I said the car does run fine though I have noticed that it is a little harder to get it to idle just rght. Though by adjusting the idle screw it will eventually sit at 850 just fine. The car does not smoke unless I am full throttle (The smoke is mostly dark) and I see no oil on the plugs at all. Just wondring if anyone had any ideas. Oh Sorry: it's a 1975 1.8 Stock FI Thanks, |
Lo-Fi Version | Time is now: 2nd July 2024 - 10:47 AM |
