seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
Do I run:
6's & 7's (I have 2 - 6's and 4 7's in Indy) 7's 6's (I have 2 6's in Indy and 4 on my blue car -until the flares are on-but it's in LA) Car is a 2.0 Euro-stock fendered (and plan it to stay that way). It may get a six in a year or so. 3 Season nice day car. Whichever way I decide the wheels are going to Al Reed for refinishing. |
cgnj |
Senior Member ![]() ![]() ![]() Group: Members Posts: 627 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None ![]() ![]() |
I hve 6's and 7's on my car. Had to bat them to get the 7's on. Run sixes unless you want to play body man.
Carlos |
VegasRacer |
ELVIRA ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,527 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None ![]() ![]() ![]() |
Run the sixes and sell me the sevens.
boxstr |
MEMBER:PACIFIC NORTHWEST REGION ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest ![]() |
Stock body 914s look great with 7x16s.
CCLINFUCHSWORLD |
Gary |
Senior Member ![]() ![]() ![]() Group: Members Posts: 744 Joined: 12-January 03 From: Mount Airy, MD Member No.: 134 Region Association: MidAtlantic Region ![]() ![]() |
7" Fuchs won't fit out back - also batted mine and was sorry for it. It cracked the paint. Even then I ran 205's on the 7's.
205 tires on 6's worked fine. I wouldnt imagine you need much more with a 4 cylinder motor, especially stock. Now, I recall 7" cookies or phone dials working - different offset. JP - was that you? |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
I was able to get 6" early Fuchs to fit 205's with no problems.
When I went to 7" cookies I had to roll the rears pretty well to get them to fit, plus cracked the hell out of the paint. Geoff |
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
16x6's all the way around!
Jeff Attached image(s) ![]() |
John2kx |
Senior Member ![]() ![]() ![]() Group: Members Posts: 502 Joined: 22-August 03 From: Augusta, Ga. Member No.: 1,066 ![]() |
I run 7's out back and 6's in front. Had to pull the rears about 3/4" using 205/55/16 tires.
Have seen one 914 with 7's all around that did not require any mods. He was using 205/40/16s. I prefer the look of the 7 inch rim and am considering buying a pair for the front of my car. John |
si2t3m |
914 addict ![]() ![]() Group: Members Posts: 346 Joined: 9-January 03 From: Qc, Canada Member No.: 119 ![]() |
Running 6's up front with 205/55/16 tires and 7's in the back with 225/50/16 tires. Yup had to bat the rear fenders a bit. The 225's on 7's tuck under the fender but too close to my taste, thats why i rolled the rear fenders. It cracked the paint, i cleaned it up and touched up with a paintbrush, sanded and polished and it doesn't look too bad. It's not concours (and it will never be).
I tried the 7's up front and it looks better that with the 6's. I'd go with 7's in back and front with 205 up front and 225 in the rear (if it fit's). I do have some camber in the rear so it help to tuck them in. Marc-André |
dakotaewing |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region ![]() ![]() |
If you want to run 7's in the back and NOT bat the fenders, you can do what Rich Johnson did on his
yellow car and machine the rear arms to fit the 7's.. However, I don't know the details, but remember him saying it was a pain, took a lot of time and $$$... Thom (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) |
Gary |
Wes Hildreth at H&H did it for him. He narrowed the trailing arms. Rich still can only run 205's on 7" fuchs though.
machina |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 ![]() ![]() |
Definitely 7" fuchs. The deeper dish on the wheel looks much better than the flat look of the 6" wheels. We are required to run the 15" wheels in our class and their lighter weight and smaller diameter is a plus anyway.
Also consider that running the same size wheel and tire at all four corners makes tire management easier. I can swap tires front to rear when necessary, we don't have the heavy rear weight bias like a 911 anyway. regards, david Attached image(s) ![]() |
boxsterfan |
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California ![]() |
So 16x7's FUCH's will fit in the front and back? Or is it only if a certain offset or other mod to the trailing arms is made?
I want to run 16x7 FUCH's on my 3.2L conversion without batting any of the corners.... |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
QUOTE Wes Hildreth at H&H did it for him. He narrowed the trailing arms. Rich still can only run 205's on 7" fuchs though. Timo also did this modification as well, in fact I believe he built his own fixture for it, pretty slick !!!! What I'd like to see, is someone do the above modification, but take it even further and re-design or notch the trialing arm, re-locate the rear shocks (at the top) and modify the rear trunk walls so that widened Fuchs can be fully tucked under the car with no fender flares at all (IMG:style_emoticons/default/smile.gif) (starting with a 6" or 7" Fuch and widen it out to something like 9" or so with all the new material on the inside) This would be easier with an non-trailing arm suspension from a 993 (I think) or even a Boxster (A-arm type setup I think???) |
boxstr |
205/45/16 Dunlops were on all four corners when I was running 16x7s with the 911 offset on my yellow 75 and they did not require a bat job.
CCLINFUCHSVILLE |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
boxsterfan,
You can run 7's front and rear. It comes down to what size tire you want run. Typically you cant run anything larger on a 7 than you would on the 6. It also has a LOT to do with what tire manufacturer you go with. Not all tires are measured equal. A 205 race Hooiser measures 225 (as an example) B |
Rockaria |
ZippidyDoDah... ![]() ![]() ![]() Group: Members Posts: 817 Joined: 2-May 03 From: Southwest, USA Member No.: 645 Region Association: None ![]() |
7X16 205/55 in the rear with a little rolling "ROCKS!!!"
(IMG:http://lib.nmsu.edu/~clandt/914/images/914it3.jpg) Just take your time and go at the rolling slow and easy and it will work out really nice. I have 6X16 205/55 on the front and the combination looks very classy! |
Lo-Fi Version | Time is now: 2nd July 2024 - 10:46 AM |
