9 Pages V « < 5 6 7 8 9 >
> Spoke's Green 914 Progress Thread, 1974 914 2.0
Spoke
post May 9 2007, 07:25 PM
Post #121
Jerry
Took the grinder to the console rust. There's a hole in the console upright which was hidden by the outside support piece.
So should I be looking elsewhere for rust? How bad does this look? I've poked around and didn't find any soft spots. What is the gauge of steel? Is this 16 gauge?
Gint
post May 9 2007, 08:20 PM
Post #122
Mike Ginter
Damn.
Make real sure that nothing is soft in there. I'd seriously consider getting a new suspension ear and doing it "100%", "while you're in there". You don't want to spend time repairing that area and finding out later that the console gave out from rust that you could have sured today.
highways
post May 10 2007, 05:16 AM
Post #123
Yes, do the whole thing. You don't want to see this...Attached Image
Spoke
post May 26 2007, 10:20 AM
Post #124
Jerry
I've grinded all the soft stuff out. I will weld up patches on all the missing parts and put it back together and seam weld everything. Haven't seen anything else soft on this side and driver's side.
Spoke
post May 26 2007, 07:01 PM
Post #125
Jerry
A little break from body work and fender repair to "upgrade" the tach from a 74 with single turnsignal indicator to 72 with individual turnsignal indicators.
Also will add a 3000uF capacitor to the tach windings to reduce the overshoot of the stock tach.
Removed the needles and faceplates. Old plate on the left new plate on the right. Tach in center was used to test the operation with the capacitor.
Here's the tach with the capacitor to test fit its placement. I will hot melt glue the cap to the turnsignal tubes to secure it.
Spoke
post May 26 2007, 07:19 PM
Post #126
Jerry
Capacitor wired and hot-melt glued into place. Glued the wire at the tach board edge and capacitor top for strain relief from vibration.
With the faceplate and needle installed, a little blurry test of the turnsignal and highbeam indicators. Ready for a road test to check for operation before replacing the glass and bezel. I am also replacing the glass as the one from my 74 had a plastic lense and the 72 has a glass lense.
Spoke
post Jun 7 2007, 12:30 AM
Post #127
Jerry
I have a set of lamps for the turn signal indicators from the old tach that I had. Added a length of wire to reach to the emergency flasher switch. I'll tap on to the front or rear turnsignal lamps which connect to the switch.
Turnsignal indicators soldered to the turnsignal lamps.
Here's the dash all refurbished and ready for install. The trim rings and frame were in good shape so I just cleaned and waxed them. Among the refurbishments:
Backdated tach with separate right and left turnsignal indicators. I used the old tach case, faceplate, and glass. The 74 had a plastic lense. From the 74 I used the tach mechanism, needle and faceframe. Painted the needle with red flourescent paint.
Added 3000uF capacitor across the tach windings to get rid of the bouncing. This cap worked wonders in calming the needle. Now the needle moves smoothly high and low without any bouncing or overshoots. I think 3000uF is a bit too much. The tach at times seems a bit lethargic in response but the stability of the needle makes up for it.
Opened up the speedometer and cleaned the faceplate and glass and painted the needle. The speedo's lense was the only glass lense on the car when I bought it.
Opened the gas/temp gauge to replace its plastic lense with a glass lense. Painted the needles on both gauges.
TravisNeff
post Jun 7 2007, 12:42 AM
Post #128
Nice job! Can you explain tach overshoot? tach bounce?
Spoke
post Jun 7 2007, 06:03 AM
Post #129
Jerry
QUOTE(Travis Neff @ Jun 7 2007, 02:42 AM) *
The tach needle is a very free moving mechanism. The tach electronics convert the opening and closing of the coil points or electronic ignition into a DC voltage. The DC voltage is proportional to the speed of the engine thus the tach needle goes up with increased engine speed and down when engine speed is decreased.
If the dc voltage on the needle is allowed to change rapidly like when the throttle is blipped in neutral or when the engine is slowed quickly, the tach will jump up or drop quickly to the correct engine speed but then overshoot because of its own momentum. The overshoot then oscillates a couple of times before settling down to the correct engine speed.
A capacitor across the needle windings dampens the change of voltage thus making the needle movement slower and eliminating the overshoot. The bigger the cap the more damping action. Just the right amount of capacitance across the windings will yield a nice fast response without the overshoot. 3000uF like I used is too much. If I dig into the tach again, I'll change to perhaps 2000uF which should give more responsive operation without bouncing around.
Spoke
post Jun 7 2007, 06:30 AM
Post #130
Jerry
OK, back to the welding.
I've had a change of plans for the green car. Plan was to do the body work on the rear flares and paint. But the clutch in the red 914 is starting to slip pretty bad. Too much throttle in 3rd, 4th, or 5th gear will start the slipping. Acceleration is really touchy. So it's time to get the red car off the road. I have a new engine to go in along with a clutch which hopefully is in better shape than the one on the car now.
I can't have 2 914s and neither are operational so the green car will be repaired and put back together without finishing the bodywork. The bodyword will be finished as time permits between spirited drives (IMG:style_emoticons/default/driving.gif)
Filled the 6 holes from where the reflector was mounted. My welding sucks but I'm getting better all the time. Can't run a full bead yet. I tried the stop/start method, running a bead about a 1/4 inch and stopping. Learning proper speed and power settings.
Welded up the little holes under the tie plate with 14 ga steel. Seam welded everything I could see from this vantage point without removing the engine or rocker panel. Will go back on the seam welds when the tie plate is welded.
Spoke
post Jun 8 2007, 09:58 PM
Post #131
Jerry
With a piece of cardstock, I fashioned a template for the replacement tie strip.
Tie strip cut from 14 ga steel. Bend and final shaping and its ready for welding.
Spoke
post Jun 8 2007, 10:01 PM
Post #132
Jerry
Welded up the metal around the taillight which was pancaked from a shunt. When I un-pancaked it, or as my neighbor would say, "I un-fucked it", the metal tore open so had to be welded up. The rear quarter panel is just about ready for final shaping.
Tie strap welded in and excess weld grinded down and ready for paint.
It was no wonder that this tie plate rusted out as the edges of the plate were not welded all the way around and several openings were left un welded and un-seam sealed.
Spoke
post Jun 9 2007, 05:09 AM
Post #133
Jerry
Sanded and degreased the area for painting. Rattle canned the primer and used my airbrush to put down the final coat.
I only painted the area around the console repair. I resisted the desire to paint the entire wheel well or even paint and seam weld the driver's side. You know, avoiding the "while I'm in there" syndrom.
I didn't paint or seam seal the entire console since I couldn't remove the rocker panel since the car is wedged in the corner of the garage and it didn't have its back wheels on to move it. Will finish this job later when I pull the rockers.
Spoke
post Jul 20 2007, 10:03 PM
Post #134
Jerry
Keeping with my theme of doing small jobs while keeping the car on the road, next little job is to smooth the back panel after welding the holes and paint it.
After straightening the back panel, I applied a layer of glaze for the final coat.
Spoke
post Jul 20 2007, 10:16 PM
Post #135
Jerry
Only painting the outside and inside of the panel as well as the trunk lock support member.
I'm airbrushing the paint on to maximize the pint of paint left. Still need to do both rear fenders as well as a rust spot on the front passenger fender.
Spoke
post Jul 20 2007, 10:18 PM
Post #136
Jerry
All painted and emblems reattached.
jonferns
post Jul 21 2007, 05:19 PM
Post #137
Looks good
Spoke
post Aug 13 2007, 06:32 AM
Post #138
Jerry
Next job is to get the back of the car cleaned up, rust-wise, install the rear swaybar brackets, and eventually put the muffler heat shield back on.
For now, need to sandblast the rear trunk floor top and bottom. Just surface rust so no major work needs to be done other than cleanup rust and paint.
I tried to cover everything on the car to make sure the sand doesn't penetrate into unwanted areas. Even covered up the jack and trunk lock mechanism.
I have many old bedsheets which work good in protecting the car from flying sand.
Spoke
post Aug 14 2007, 05:07 AM
Post #139
Jerry
Sandblasted and painted some other parts including rear swaybar and muffler hanger.
tdgray
post Aug 14 2007, 03:39 PM
Post #140
Lookin Good Spoke... keep it up.
- Lo-Fi Version Time is now: 31st October 2024 - 10:28 PM
