9 Pages V « < 3 4 5 6 7 > »
> Spoke's Green 914 Progress Thread, 1974 914 2.0
rjames
post Jan 16 2007, 07:13 PM
Post #81
I'm made of metal
My guess is that if you replace the hoses you'll be rid of the smell. I have the same exact thing happening, and the fuel pump and filter are new. The only things not new are the fuel lines up front- I'll be doing that when I go to remove the tank to install a sway bar this spring.
martinef1963
post Jan 16 2007, 09:07 PM
Post #82
The Saga Continues...
QUOTE(Spoke @ Mar 13 2006, 11:17 PM) *
Before and After I added a little wheel bling. Wheels from my red car.
Spoke
Damn - I was going to ask if you were getting rid of the 4-lugger.... (IMG:style_emoticons/default/biggrin.gif)
Spoke
post Feb 9 2007, 04:56 PM
Post #83
Jerry
OK, took the gas tank apart. Outside of the tank looks good.
Spoke
post Feb 9 2007, 04:57 PM
Post #84
Jerry
When I pulled the fuel gauge sender out, it came out in pieces, as the little nut on the bottom had unscrewed itself and dropped to the bottom of the tank.
Spoke
post Feb 9 2007, 05:00 PM
Post #85
Jerry
Inside of the tank looks very good. The only rust that I could see is in the bottom left of the pic. Don't think I'll be resealing the tank.
What can I used to clean out the gum out of the tank?
rjames
post Feb 9 2007, 06:00 PM
Post #86
I'm made of metal
I'm sure others will chime in here, but do a search as I think there've been a few past threads regarding cleaning up the inside of a tank. (IMG:style_emoticons/default/beer.gif)
Spoke
post Feb 9 2007, 09:07 PM
Post #87
Jerry
In the #26th post in this thread, Sir Andy pointed out that a dent in the front trunk was the sign of impact damage.
He, being Sir Andy, was 100% correct. As I took the car apart, I've seen other damage or repairs from at least 1 front end impact.
The driver side A-arm that I replaced as part of the 5-lug was bent such that the position of the ball joint on the arm was about 1/2 inch more rearward than the passenger side arm.
The front panel below was replaced in its entirety. I'm assuming the piece was welded on but its obvious now that the seam is rusting on both sides.
The other thing is the piece doesn't have the bolts to hold on fog lights. There's a flat spot on the front where the bolt should go. How can I determine where the bolts should go for fogs?
Johny Blackstain
post Feb 10 2007, 10:13 AM
Post #88
QUOTE(Spoke @ Feb 9 2007, 10:07 PM) *
Just a thought- put the bumper back on w/out the grills & mark where you think the fogs should be. Use the circle as your guide by just placing the grills in place. Then, take off the bumper, grab a fog light w/ bracket, hold in place & mark out where the hole should be. (IMG:style_emoticons/default/thumb3d.gif) (IMG:style_emoticons/default/cool_shades.gif)
scotty b
post Feb 10 2007, 11:44 AM
Post #89
rust free you say ?
QUOTE(Spoke @ Feb 9 2007, 03:00 PM) *
Kerosene, diesel fuel, laquer thinner
Spoke
post Feb 10 2007, 12:36 PM
Post #90
Jerry
A little rear end bling. Eric Shea hubs, 180LB springs, and new bearings. The hubs are very nicely done. Quite a difference from the converted hubs on the car. The hubs on the car do not have the extra bosses around the studs thus some studs are longer than others. Plus not all are straight and they have been welded to the hub.
Eric, do you want the hubs that are on the car? As mentioned, the lugs are welded to the hubs. I believe the hubs are the later style.
Once the gas tank is cleaned and fuel hoses replaced, I'll finish up the 5-lug rear end including installing the rear factory swaybar.
Spoke
post Mar 7 2007, 10:09 AM
Post #91
Jerry
OK, I finally started to work on the 914 again after the winter freeze. Also changed the name of this thread since I've now had the car for 1 year.
Cleaned out the gas tank cavity. Removed the undercoating and cleaned out all the junk. Looks a little nicer now.
Putting in the electric washer pump now.
Bought a generic pump from my FLAPS and decided to mount it out of the way under the cowling.
Spoke
post Mar 7 2007, 10:13 AM
Post #92
Jerry
I wanted to mount the washer pump out of sight and didn't want to drill holes into the car to mount.
So I got a long tiewrap and fastened it to the cowling upright. As briefly as this pump is used, this fastening will be fine. I couldn't mount it where SirAndy did since the inlet and outlets were not in the same positions.
The wires for the pump nicely route into the interior directly behind the pump.
Spoke
post Mar 7 2007, 10:20 AM
Post #93
Jerry
Found this bolt lodged in the seam sealer and painted. Unless the PO dropped this bolt and then painted the area, this bolt came from the original manufacture.
Eric_Shea
post Mar 7 2007, 11:04 AM
Post #94
PMB Performance
I do need cores but... probably not those, since you sent those arms I think we be good.
There was a certain 914-6 (2233) that has a 10mm nut in the seam sealer in the rear trunk (IMG:style_emoticons/default/biggrin.gif)
That car is Saturn (Chrome) Yellow no?
Aaron Cox
post Mar 7 2007, 11:13 AM
Post #95
Professional Lawn Dart
nice work! you turned those wheels into real beauties....!!
love the flares!
Part Pricer
post Mar 7 2007, 12:08 PM
Post #96
Believe everything I post
QUOTE(Eric_Shea @ Mar 7 2007, 12:04 PM) *
No. It is Ravenna Green.
Eric_Shea
post Mar 8 2007, 11:06 PM
Post #97
PMB Performance
Gottcha (IMG:style_emoticons/default/wink.gif)
I went back through the thread and saw that... it's so weird though... some of those pictures are spot on for Saturn and others look green. Post 87 looks like Saturn. The first pic in post 91 too... (IMG:style_emoticons/default/wacko.gif)
Spoke
post Mar 18 2007, 11:43 AM
Post #98
Jerry
Intalled the washer tank. The pump can be seen at the bottom of the cowl brace. Drilled out the cap as per Sir Andy's thread. Also connected all wires to the washer arm on the steering column. I decided to put the switch on the ground side of the pump.
Spoke
post Mar 18 2007, 11:49 AM
Post #99
Jerry
Cleaned out the tank and sending unit with degreaser from my FLAPS. The stuff did a job on the built up gum and residue in the tank and the sending unit. I mixed the degreaser with hot water in a about 1:4 (degreaser:water) ratio. Compare these pics with the ones a few posts ago for before and after cleaning.
Spoke
post Mar 18 2007, 04:27 PM
Post #100
Jerry
Pulled the front trunk gasket so to fix the rust on the passenger fender. Rust also on the driver side but hasn't worked its way up to the exposed fender.
- Lo-Fi Version Time is now: 31st October 2024 - 08:20 PM
