EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
With a loose Oil Breather (the wire clamp), how much oil can leak and where? I have oil on top of my engine and a fairly good leak on the front side underneath. I need to figure out if I need to look for more oil leaks (ie oil pump). Thanks. (IMG:style_emoticons/default/cool.gif)
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Its the breather. Promise. Snag the bail clip from your other engine and install it.
B |
EdwardBlume |
Its loose too. Dad's car is tight, but I'm not messing with it. I'll be visiting Rich tomorrow. Need anything? Also, is Tony booked or what? I was hoping to get a CB before the next GGR AX but he's hasn't gotten back to my email. Do think he might be able to squeeze it in?
Brad Roberts |
He is at Thunderhill right now for 2 open track days. He might have gotten back this evening. I was at Richs today. Missed your call while I was at WEVO. You have a new gasket and their was nothing wrong with the actual breather. You just need a good bail clip.
B |
EdwardBlume |
OK- I'll get one and install it.
I just sent you an email at brad@all914.com regarding adjustable rear drop links for a stock swaybar. Can I avoid pulling and mailing the pieces?? THANKS. |
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
EdwardBlume |
Breaker. Breaker. I meant Corner Balance.... Over. (IMG:style_emoticons/default/finger.gif)
Drums66 |
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region ![]() |
Cavwpguy, try bending the bail clip to tighten it, sometimes you can salvage them and they will work out (IMG:style_emoticons/default/wink.gif)
Brad Roberts |
Yeah.. that is what I did with the current bail clip... it might have lasted a week before it was loose again.
B |
Drums66 |
On the other claw............I did that and it worked for me.........try it! what do you have to lose but more of your time! mine hasn't leaked yet..........4000mi's ago (IMG:style_emoticons/default/wink.gif)
EdwardBlume |
Drums66 |
Yes there is........but as you probably know..you can't take metal back and forth to many times because it is weakened and will break....but yes those hold on very Snug!
Lo-Fi Version | Time is now: 2nd July 2024 - 10:11 AM |
