Blynes |
Member ![]() ![]() Group: Members Posts: 68 Joined: 19-January 03 From: Savannah, GA Member No.: 169 ![]() |
We are ready to run the front oil cooler lines on my 6 conversion.
Does anyone have any recomendations on material and routing? Bill |
drew365 |
These are the good old days! ![]() ![]() ![]() ![]() Group: Members Posts: 2,004 Joined: 29-December 02 From: Sunny So. Cal. Member No.: 37 ![]() |
Alot has to do with if it's a street car that needs heat? I ran through the passenger long, into the footwell and up into the front trunk. But I don't need no stinkin heat, it's too damn hot here anyway.
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,714 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
QUOTE(drew365 @ Sep 5 2003, 07:22 AM) Alot has to do with if it's a street car that needs heat? I ran through the passenger long, into the footwell and up into the front trunk. But I don't need no stinkin heat, it's too damn hot here anyway. yepp, that's the way to go ... if you need heat, you can drill holes (yieks (IMG:style_emoticons/default/icon8.gif) ) in the rear firewall, right above the floor next to the passenger long and route it alongside the long, then through a channel under the tank and out into the front trunk. see attached pic ... Attached thumbnail(s) ![]() |
man, i can't believe my car looked that bad just a year ago ...
we need a shaking head smily, Andy |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
You can run the lines in the rocker panels and have them enter inside the fenderwell to the front trunk.
I suggest -12 braided line if your budget can handle it... if not. Buy some high temp 1 inch rubber line. B |
Blynes |
This is mainly a track car.
I've got all the heat I can stand. Was thinking of running aluminum lines because of heat dissipation but would like to avoid running in the passenger compartment because of the heat. I read somewhere about running lines inside the rockers following the path that AC lines would have been run. This may be easier with braded lines. Pictures anyone? BL |
Brad Roberts |
I cant find the ones I'm looking for.
Run the lines inside the heater tube.. then have them exit right near the floor in the passenger side footwell. The fram rail has a small exit that I enlarge. Then you go to the factory GT line "hole" and rout into the front trunk. B |
Brad Roberts |
tgjhhgfj
Brad Roberts |
This is where it will exit into the front trunk. The line for the windshield washer runs thru here. Its a small frame rail..
B |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Andy, you paid money for that!!!
QUOTE(Bleyseng @ Sep 5 2003, 01:07 PM) Andy, you paid money for that!!! yepp, i did ... |
Brad Roberts |
If he hadnt of bought that car.. he wouldnt be world famous for hosting the 914club site.
B |
ChrisReale |
Sleazy ![]() ![]() ![]() ![]() Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 ![]() |
For a 914-4, what size lines do you want to run to allow for proper flow?
QUOTE(ChrisReale @ Sep 5 2003, 02:04 PM) For a 914-4, what size lines do you want to run to allow for proper flow? dash 12 braided lines all the way ... |
Brad Roberts |
Chris,
I run -12 because 99% of the cars I build will be 9146 conversion cars one day... and guess what ? The -12 and cooler will be perfect for any six installed later. I try to think ahead. B |
Lo-Fi Version | Time is now: 2nd July 2024 - 10:14 AM |
