> How to build a set of GT door panels...
Aaron Cox
post Feb 22 2006, 12:04 AM
Professional Lawn Dart
planning to copy dan's RS america handle'd smooth vinyl setup (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
(IMG:http://www.914world.com/bbs2/uploads/post-2-1139878907.jpg)
first - you need a set of core early door paels, with the one piece metal top.
(IMG:http://www.914world.com/bbs2/uploads/blog-1140414498.jpg)
cores...
(IMG:http://www.914world.com/bbs2/uploads/blog-1140414506.jpg)
then - source some new laser cut piece from evilwerks/burrowerks
(IMG:http://www.914world.com/bbs2/uploads/blog-1140414512.jpg)
begin taking apart old core door panels. note the solid metal tops....
(IMG:http://www.914world.com/bbs2/uploads/blog-1140414518.jpg)
again
(IMG:http://www.914world.com/bbs2/uploads/blog-1140414548.jpg)
begin prying up old staples.....
(IMG:http://www.914world.com/bbs2/uploads/blog-1140414540.jpg)
after removing vinyl and foam covering, begin to pry up the tabs holding the metal top to the core board...
(IMG:http://www.914world.com/bbs2/uploads/blog-1140414529.jpg)
notice the "tuck and roll" (remember how this was done....)
(IMG:http://www.914world.com/bbs2/uploads/blog-1140414562.jpg)
the old top with the new board....
(IMG:http://www.914world.com/bbs2/uploads/blog-1140573228.jpg)
begin pushing holding tabs down on new board. the butt of a screwdriver werks great.
(IMG:http://www.914world.com/bbs2/uploads/blog-1140573239.jpg)
completed backboard....
(IMG:http://www.914world.com/bbs2/uploads/blog-1140573275.jpg)
Aaron Cox
post Feb 22 2006, 12:06 AM
cut out new 1/4" headliner material to pattern of core board.....
(IMG:http://www.914world.com/bbs2/uploads/blog-1140573284.jpg)
attached with 3m super 77 spray adhesive...
(IMG:http://www.914world.com/bbs2/uploads/blog-1140573302.jpg)
cut out door handle cutouts and window mechanism....
(IMG:http://www.914world.com/bbs2/uploads/blog-1140587456.jpg)
prepare to adhere vinyl to headliner foam material
(IMG:http://www.914world.com/bbs2/uploads/blog-1140587479.jpg)
put new smoooth vinyl down, rubbing it into the adhesive below
(IMG:http://www.914world.com/bbs2/uploads/blog-1140587490.jpg)
fold back into the tabs to redo the tuck and roll.....
(IMG:http://www.914world.com/bbs2/uploads/blog-1140587511.jpg)
Aaron Cox
post Feb 22 2006, 12:10 AM
i told you not to forget how this went together....
(IMG:http://www.914world.com/bbs2/uploads/blog-1140587450.jpg)
make the carboard tabs to make the line straight and not wavy.....
(IMG:http://www.914world.com/bbs2/uploads/blog-1140587520.jpg)
cardboard (left) vs no cardboard tabs (right)
(IMG:http://www.914world.com/bbs2/uploads/blog-1140587563.jpg)
cardboard tabs completed.....
(IMG:http://www.914world.com/bbs2/uploads/blog-1140587575.jpg)
glue next layer of headliner material over the tabbed portion....
(IMG:http://www.914world.com/bbs2/uploads/blog-1140587586.jpg)
trim excess and begin to glue the top tuck and roll portion... a real pita. get the right glue and tons of closepins/clamps....
(IMG:http://www.914world.com/bbs2/uploads/blog-1140587593.jpg)
here is what it looks like when pulled over and not glued.
(IMG:http://www.914world.com/bbs2/uploads/blog-1140587602.jpg)
Aaron Cox
post Feb 22 2006, 12:11 AM
will be updated and for the most part finished tomorrow......
redshift
post Feb 22 2006, 12:17 AM
Bless the Hell out of you!
(IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
That stuff doesn't look used... or free!
Are you doing this for someone else?
GOOD DEAL!
M
736conver
post Feb 22 2006, 12:21 AM
Looks good.
I have a pneumatic staple gun and 5/32 staples. Works like a charm. Only had to glue the top. If you want to borrow it let me know.
Dont forget to clean the top metal piece before you reglue. And dont use to much glue it starts to eat the material. Thats the mistake I made the first time.
MattR
post Feb 22 2006, 01:29 AM
Clean your fingernails or get a hand model (IMG:http://www.914world.com/bbs2/html/emoticons/ph34r.gif)
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
looks good, kid
Jeroen
post Feb 22 2006, 04:49 PM
Region Association: Europe
nice work!
smells like a classic thread to me
Aaron Cox
post Feb 22 2006, 11:33 PM
ok... the new glue to glue the top....
3m super strength adhesive from home depot. hold it for 5-10 min and then its on its own.....
(IMG:http://www.914world.com/bbs2/uploads/blog-1140672532.jpg)
now, the stapling. 1/4" were smallest available. although probably fine on their own, i used vinyl scraps as washers....
you cannot feel the staple from the front.
PULL and staple. Stretch and staple....
(IMG:http://www.914world.com/bbs2/uploads/blog-1140672550.jpg)
trim off the excess later after stapling.... making room for the door panel clips etc.....
The 90 percent finished product. need to let it dry before i finish the sides.....
RSA handles on order....
(IMG:http://www.914world.com/bbs2/uploads/blog-1140672557.jpg)
Brando
post Feb 22 2006, 11:41 PM
BUY MY SPARE KIDNEY!!!
that looks INCREDIBLY slick... no armrest... nada, very clean and crisp.
rhodyguy
post Feb 23 2006, 08:34 AM
yep. it's a classic. real slick aaron (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) . combine the new units with "vapor barriers for dummies", and it's a thing of beauty. so where did you get the backing panels?
k
Dr Evil
post Feb 23 2006, 08:42 AM
Send me your transmission!
Nice! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) Did you foam between the metal top and the vinyl? I did my set like this, but I have stitched lines on them too. I am thinking of using velcro to mount them as it is easier and may be better in the long run. Another "performance enhancement" is to use some neoprene lining on the back to dampen the noise from the out side.
Dr Evil
post Feb 23 2006, 08:45 AM
Oh ya, since the early metal door tops were always a pain for me to find I am working on having some made from a polymer by a local. If so I will be selling panels again. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
I am glad that you took pics. People always had a hard time understanding that the whole top of the early panels were metal, not just the tabs.
Jeroen
post Feb 23 2006, 08:54 AM
what years have the metal top on the panel?
jasons
post Feb 23 2006, 08:55 AM
Jackstand Extraordinaire
Those look killer. Maybe a classic thread?
BTW Did you consider trying to get the RSA nylon webbing door release to work with the 914? I've wondered how difficult that would be.
seanery
post Feb 23 2006, 09:20 AM
waiting to rebuild whitey!
(IMG:http://www.914world.com/bbs2/html/emoticons/thumb3d.gif) sweet job AAAAAAaaaaron (IMG:http://www.914world.com/bbs2/html/emoticons/thumb3d.gif)
Aaron Cox
post Feb 23 2006, 11:30 AM
QUOTE (Dr Evil @ Feb 23 2006, 07:45 AM)
rofl mike... i was going to do velcro also.....and a mylar barrier on the back.
yep, there is apiece of foam over the metal top....
mike, how did you stitch the line thru the carboard? or you did it thrue the foam?
mike_the_man
post Feb 23 2006, 03:57 PM
I like stuff!
Aaron, where did you get the RS style door pulls? I've been thinking of doing this exact same thing. Thanks for the how-to! I was also wondering about how to use the red nylon webbing for the inner door handles. Anyone have thoughts on this?
Aaron Cox
post Feb 23 2006, 03:59 PM
QUOTE (mike_the_man @ Feb 23 2006, 02:57 PM)
i thought about the red handle, but i like the ability to lock the car from the inside (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
the RSA handles im ordering from pelican, 18 bucks a pop....
these are original 911rs/9146 GT handles...
(IMG:http://i6.ebayimg.com/05/i/06/39/2a/b5_1.JPG)
(IMG:http://i24.ebayimg.com/01/i/06/3f/da/95_1_b.JPG)
RS America
(IMG:http://www.pelicanparts.com/catalog/images/interior/911-930RSA_Dr_Pnl.jpg)
TINCAN914
post Feb 23 2006, 04:21 PM
Summer's Commin...
Nice work Aaron, thanks for sharing... (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
- Lo-Fi Version Time is now: 2nd April 2025 - 01:38 AM
