914zim |
Still pretty clueless... ![]() ![]() Group: Members Posts: 221 Joined: 29-July 03 From: New Berlin, WI Member No.: 962 ![]() |
Now that I got your attention... (IMG:style_emoticons/default/laugh.gif)
I noticed that my rear brake calipers have both an upper and a lower bleed nipple like the fronts. Does this mean a PO put front calipers on the rear? I also noticed the P-brake isn't connected either, which I think is another indication. I am going to order the rebuild kits, but I want to know if I should order 4 front kits. Where should I get the kits from and how much are they? Any info is appreciated... Andy... (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) |
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
Nope.....lower nips are useless....upper ones allow ya to bleed bubbles per Newton's law....
Joe Bob |
Double nips for the ....curious....
http://www.bmezine.com/pierce/08-nipple/multi001.html |
MarkV |
Fear the Jack Stands ![]() ![]() ![]() Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None ![]() |
Could have gone all night without seeing that. (IMG:style_emoticons/default/w00t.gif)
Joe Bob |
At least I did not post 'em.... (IMG:style_emoticons/default/bootyshake.gif)
MarkV |
True
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,714 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
QUOTE(mikez @ Sep 5 2003, 09:21 PM) Double nips for the ....curious.... http://www.bmezine.com/pierce/08-nipple/multi001.html nice link Z. my last girlfriend (before i got married) had 34 piercings ... i'll let you guess where (IMG:style_emoticons/default/rolleyes.gif) i like 'em, Andy as for the calipers, don't use the lower nipples for bleeding as you will have air remaining in the upper part. |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
MarkV, here is a pic of your long lost avatars buddy. shhh He's still sleeping.
Attached image(s) ![]() |
MarkV |
Yikes (IMG:style_emoticons/default/w00t.gif) What the hell is it ?
A: Small Kangaroo B: Iguana C: Monkey D: Alien |
Bleyseng |
A dead hairless rat!
Mockmaw |
Member ![]() ![]() Group: Members Posts: 163 Joined: 18-March 03 From: Berkeley/San Diego, CA Member No.: 438 ![]() |
That is a big friggin rat, especially when you use that electrical socket for scale. Looks like it's straight from the Pleistocene, sheesh..
Any idea why the rear calipers have two nips? Does that mean they're interchangeable between sides of the car (left and right)? |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
He needs to check and see if the lever arm is on the bottom of the caliper for the Ebrake. If they have NO arm.. then the PO put fronts on the rear.
B |
914zim |
Thanks guys for the help and lols!!!
I was wondering what crazy posts my message would bring out (IMG:style_emoticons/default/smile.gif) Here's an update... I do have the E-brake arm on the bottom of the calipers on the rear, so I guess they are true rear calipers, even if they do have an upper and a lower nipple - correct? Today, I took both rears off and split them, removed the pistons (pretty grungy). I'm very sure there were completley seized up. I am going to order the rebuild kits online tonight. Do I clean everything up with brake cleaner only? Thanks again for all the help. Andy... |
Brad Roberts |
You will clean them up with brake cleaner and re-assemble them with brake fluid.
B |
tod914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 ![]() |
cool rat picture. looks like the crypt keeper.
Lo-Fi Version | Time is now: 2nd July 2024 - 10:29 AM |
