questions about brakes and master brake cylinders |
biosurfer1 |
Sep 5 2003, 11:27 PM
Teener fo Life! Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
i have the bmw 320 brake upgrade in my 914, and the master brake cylinder has been acting up, i found on on ebay, its a 19MM Dual circuit brake master cylinder, just wanted to check and see if there is any reason this wouldnt work with those brakes?
thanks |
Sep 6 2003, 12:00 AM
Resident German Group: Admin Posts: 41,714 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
how much is it?
the 19mm is a common 911 part. you can buy it brand new from porsche. wasn't that expensive either ... Andy |
ChrisFoley |
Sep 6 2003, 07:40 AM
I am Tangerine Racing Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
The 19mm M/C should work perfect with the bmw upgrade. Just get a new one and swap it out.
If it doesn't fix the problem, you will have a spare, and you will still have to find the source of the problem. |
Lo-Fi Version | Time is now: 2nd July 2024 - 10:10 AM |
