What I've Learned, since owning a 914 |
jwade |
Sep 7 2003, 12:09 PM
Member Group: Members Posts: 94 Joined: 23-February 03 From: Los Angeles, CA Member No.: 340 |
These are the things that I've learned since buying my 914. My most recent
lesson (item #1) occurred just last night: 1) Running over a separated Tire tread in the dark will rip off your air dam (DAMN) 1a) I need brighter headlights 2) How to adjust the shift linkage 3) How to R & R a rear axle 4) I don't have enough tools (also damn) 5) The people on this board are full of good advice 6) How to remove the shift fork while misdiagnosing the problem (damn again) 7) How to change a distributor 8) How to replace interior and exterior door latches 9) How to repair rubber so that the car doesn't leak (as much) 10) You can't have enough knowledge (thanks for the CD at Dunkel's Brad) 11) How to remove the bumpers (to install a bike rack) 12) I love my 914 john |
TheCabinetmaker |
Sep 7 2003, 12:20 PM
I drive my car everyday Group: Members Posts: 8,325 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
the list will get much longer, but #12 will always be the most important. Glad ya got the axle fixed.
Andyrew |
Sep 7 2003, 12:58 PM
Spooling.... Please wait Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
I have learned so much since buying a car, I would have to write a book, I think it does help that I am doing all the work myself, and that it is my first car... I think I have almost touched every bolt (not including the stuff in the engine and trani.. I'll do that with my spare stuff (IMG:style_emoticons/default/biggrin.gif) )
You learn something every day on this board. Thanks to everyone on the board! You make my life a whole heck of a lot less boring! (IMG:style_emoticons/default/beerchug.gif) Andrew |
redshift |
Sep 7 2003, 01:19 PM
Here, let me add a couple that you can just call 'learned', and skip:
13. Magnesium burns. 14. If an Escalade is closer than one car length behind you, he thinks the Suburban in front of you is the next car in his lane. M |
Joe Bob |
Sep 7 2003, 02:33 PM
15) You can regularly kick a 911's ass in AX.....
16) You can shoot a .357 out the roof at SUVs accurately..... 17) Motorcycles don't see you either.... 18) Cops think you can do over 100mph, but judges don't...... |
URY914 |
Sep 7 2003, 03:16 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 124,370 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
19) Electricity is strange.
20) Rust never sleeps. 21) Gravity never stops. Paul |
biosurfer1 |
Sep 7 2003, 03:37 PM
Teener fo Life! Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
22) anything you think will go wrong, probably wont...it'll be the 4 things you didnt think about:)
Gary |
Sep 7 2003, 04:47 PM
Senior Member Group: Members Posts: 746 Joined: 12-January 03 From: Mount Airy, MD Member No.: 134 Region Association: MidAtlantic Region |
20 a. A constantly out of adjustment clutch is a torn clutch tube
20 b. A lot of extra negative camber in the right rear is bad 23) 911 struts fit and work nice |
scotty |
Sep 7 2003, 04:52 PM
The Fun Never Stops Group: Members Posts: 773 Joined: 20-May 03 From: Portland. Oregon (SW) Member No.: 718 Region Association: None |
1b) It's also hell on headlights/signals when the idiot in the car in front of you runs over a chunk of truck tire tread ("%#@!!!")
24) Missing a 3-2 downshift (3-R) is hard to do, but possible when excited and inexperienced.... |
boxstr |
Sep 7 2003, 07:18 PM
25)A four wheel alignment will do wonders for the handling of your 914.
CCLINALIGNMENTLAND |
Hi_Fi_Guy |
Sep 7 2003, 10:49 PM
Tuetonic terror Group: Members Posts: 375 Joined: 12-August 03 From: Sunny Phoenix, AZ Member No.: 1,019 |
1C May destroy the air-dam on a 914 but on a Boxster it destroys the Airdamn, Gurney Plate, front radiator, a/c condenser, inner fender well, and the front air-damn.
Thank goodness for the simplicity of the 914. |
Bruce Allert |
Sep 7 2003, 11:00 PM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
QUOTE(redshift @ Sep 7 2003, 12:19 PM) 14. If an Escalade is closer than one car length behind you, he thinks the Suburban in front of you is the next car in his lane. M ......and, for that reason alone, is why I like ORANGE the best (IMG:style_emoticons/default/laugh.gif) Good one Miles (IMG:style_emoticons/default/smilie_pokal.gif) bruce |
VegasRacer |
Sep 8 2003, 05:02 AM
ELVIRA Group: Benefactors Posts: 8,709 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
24 a.) Going from 3rd to 2nd @6000 rpm (when aiming for 4th) is expensive.
Rusty |
Sep 8 2003, 06:26 AM
Wanted: Engine case GA003709 Group: Admin Posts: 7,952 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
26. Unbreakable tools are.
27. There is no such things as a budget for a 914 project. 28. Yes, there is enough room to get laid in a 914. 29. A good valve adjustment will cure a myriad of ills. |
TheCabinetmaker |
Sep 8 2003, 06:37 AM
28a even with the top on.
rhodyguy |
Sep 8 2003, 06:56 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,198 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
30. when you lay on the 2 tone horns, it gets people talking on the phone attention.
kevin |
Bruce Allert |
Sep 8 2003, 07:37 AM
QUOTE(vsg914 @ Sep 8 2003, 05:37 AM) 28a even with the top on. Curt & Lawrence....... THAT , in itself, deserves a FAT TIRE (IMG:style_emoticons/default/beerchug.gif) or 2 (IMG:style_emoticons/default/smilie_pokal.gif) bruce |
Rusty |
Sep 8 2003, 07:47 AM
31. Making love ON a 914 will cause dents in the hood, no matter how careful you are.
DNHunt |
Sep 8 2003, 07:48 AM
32. There is something metaphysical about these cars. Magic dust or gremlins, sometimes it works and sometimes it doesn't. Sometimes it just fixes itself (not often enough).
33. Sometimes a little tap with a BFH helps. If that doesn't help the car sometimes it help the mechanic. 34. Sometimes a beer is the best tool you can reach for. 34a. Each sucessive beer is better medicine than tool Dave |
Bleyseng |
Sep 8 2003, 08:18 AM
Aircooled Baby! Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
35. Keep Brad's number (650 All 9146) in your phone for when you can't figue it out.
Geoff |
Lo-Fi Version | Time is now: 2nd January 2025 - 10:20 AM |
