Valve Cover Gaskets ..., How do you know if they are bad/old?? |
vesnyder |
Mar 16 2006, 05:28 PM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
My vave cover gaskets are leaking so I thought I would replace. When I removed the valve covers, they seem good, albeit a little brittle. Is that a sign they need replaced? Any prep I should do to the mating surfaces? The old ones seem to be glued into the valve covers - what should I use to seal them?
ClayPerrine |
Mar 16 2006, 05:30 PM
Life's been good to me so far..... Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
When they leak, they are old.
Replace them. The gaskets are cheap. Don't be stingy here and you will keep the relatively more expensive oil in your motor where it belongs. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
newto914s |
Mar 16 2006, 08:14 PM
Senior Member Group: Members Posts: 561 Joined: 16-February 04 From: Thornton, CO Member No.: 1,663 |
Get them at Stoddard's. I was really impresed with the quality when I stopped in. They're the black rubberize gaskets. Not the cork ones.
Car looks really nice Vance (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
Cap'n Krusty |
Mar 16 2006, 08:42 PM
Replace 'em if they're brittle. Use Gasgacinch on the cover and the side of the gasket that amkes contact with the valve cover. Let them air dry for 5 minutes before slapping them together. NO sealant on the head side of the gasket! The Cap'n
flesburg |
Mar 16 2006, 09:04 PM
Senior Member Group: Members Posts: 506 Joined: 22-November 04 From: Pontiac, IL Member No.: 3,162 |
Everytime you set valves on a T4, which I always did every 5K miles at lest for the first 125K miles. The gaskets are cheap enough to consider as part of routine maintenance, and leaky ones drip right were you dont want it, on the exaust where it always stinks...
anthony |
Mar 16 2006, 11:01 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
Do what the Cap says. An old geezer at my local bug shop gave me the exact same advice. My current set of cork have 12K miles on them and have never leaked. I don't change them every time I adjust the valves either. |
Rand |
Mar 17 2006, 12:00 AM
Hey, with a label like this, you can't go wrong...
(IMG:http://www.oldbritts.com/image/78_401001a.jpg) But I don't have any on hand. Slight hijack: I'm about to adjust my valves. I bought gaskets whether I need them or not since they are so cheap. Any reason it's a bad idea to use a super-thin layer of RTV or the like to hold the gasket to the cover, or should I go pick up some Gaskacinch? |
Lo-Fi Version | Time is now: 25th June 2024 - 07:13 PM |
