rpmmaxxed |
Member ![]() ![]() Group: Members Posts: 387 Joined: 24-May 05 From: Oceanside, CA Member No.: 4,140 Region Association: Southern California ![]() |
Apart from a starting issue that may or not be solved yet(it is intermettent), My headlights and wipers, as well as my cd player are no longer receiving power.
Cleaned all fuses, contacts, nothing. All were working at one moment, parked car, and went to use them yesterday afternoon, no dice. interior lights still work, but headlights will not lift. and when manually lifted, no light. Wipers do not go on or off. Radio is dead. Any ideas guys? |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Check for power going in to the fusebox. Look at the wires at the positive battery post. The Cap'n
rpmmaxxed |
(IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) checked voltage, its there
gotta search this down. two nights with no headlights is enough... gonna end up with a Haynes manual drool encrusted to my face tonight... |
rpmmaxxed |
Really could use pointers guys. having a hard time trouble shooting this...
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
ignition switch
sometimes the "acc" contacts would close, and soemtimes I drove in the rain without wipers.... b |
Cap'n Krusty |
Color wiring diagrams, FAR better than you'll EVER find in any Haynes manual, are available on Pelican's site. You can just read them on your screen, or print them out. The Cap'n |
Solo914 |
Member ![]() ![]() Group: Members Posts: 266 Joined: 6-March 06 From: Redmond, WA Member No.: 5,678 Region Association: None ![]() |
I was just working on a very similar problem as my fresh air fan and wipes didn't work. Turns out they are on the same relay. As for wipers and headlights, I would check the wiring diagram but I think that you may have a ground problem. Check the grounds at the left front headlight bucket. I cleaned all my grounds and replaced the relay and that fixed everything. Seeing as I wanted to take care of any future problems too, I cleaned the fuse panel terminals with the copper brush on my Dremel tool. |
dimitri |
dimitri ![]() ![]() Group: Members Posts: 101 Joined: 16-March 05 From: Cupertino,CA Member No.: 3,769 ![]() |
With so many things not working at the same time, my prime suspects
would be ground cable at battery and of course the positive cable. Jank, twist and pull, see wether something comes loose. Remove cables and clean posts. Good luck. Dimitri |
Lo-Fi Version | Time is now: 27th June 2024 - 07:55 AM |
