trans /cv gasket leak |
sk8kat1 |
Mar 17 2006, 11:46 AM
Senior Member Group: Members Posts: 911 Joined: 10-October 05 From: belvidere ,IL Member No.: 4,937 |
the gasket on the drivers side is leaking how much on a PITA is it really to fix?
Mueller |
Mar 17 2006, 12:07 PM
it's 4 bolts...should take about 15 minutes......
sk8kat1 |
Mar 17 2006, 12:45 PM
does it piss fluid all over .. so I should do it when I have drained the trans to do a fluid change?
Allan |
Mar 17 2006, 12:50 PM
If you're talking about the actual paper cv gasket no. The cv is packed with heavy grease.
sk8kat1 |
Mar 17 2006, 12:58 PM
the gasket I am speaking of .. from the exploded view in the haynes manual it appears to be the one that is between the trans and the cv .. basicly it is leaking fluid down the side of the trans right wher the CV bolts to the trans
Allan |
Mar 17 2006, 01:01 PM
I'm kind of confused. There is no fluid where the cv bolts to the drive flange. Only cv grease. It sounds like you are talking about the tranny seal for the drive flange. If that's the case you'll have to pull the flange and r&r the seal. Not that big of a deal.
sk8kat1 |
Mar 17 2006, 01:13 PM
oh yea it is definately a drip .. but very small... does this other gaskeyt need to be done with the fluid drained and how long does that one take ..
Dr Evil |
Mar 17 2006, 01:21 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Remove CV axle from out put flange, you will then see a bolt in the center of the flange (it may be hidden by a bunch of grease). Lock your parking break (stops other side from turning) and remove that bolt. Pulll flange, remove old seal, replace new seal, assemble and enjoy.
dlo914 |
Mar 17 2006, 01:25 PM
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
make sure you use a 12-point-star allen socket to remove the bolts, a standard 6 point might/will, BTDT (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) , strip the bolts.
sk8kat1 |
Mar 17 2006, 01:47 PM
does the trans need to be drian ed to avoid piss-age while doing this?
Aaron Cox |
Mar 17 2006, 01:50 PM
to remove the output shaft? yes.... whats behind there... (lots of gear oil) his cv isnt leaking, it is leaking from the round seals on the outputshaft (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
dlo914 |
Mar 17 2006, 01:52 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) i do not recollect ever saying that AA (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) hehe i should've read the entire thread before quoting. Yea right after i posted the quote i scrolled up a bit and read the diagnosis. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
Mueller |
Mar 17 2006, 02:36 PM
you need to take a picture or learn how to capture an image from the PET CD and show with an arrow (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
sk8kat1 |
Mar 17 2006, 02:37 PM
so to be clear I need to buy the side output shaft seal ?
trying to find on PP |
Lo-Fi Version | Time is now: 25th June 2024 - 01:05 AM |
