LvSteveH |
I put the Poor in Porsche ![]() ![]() ![]() Group: Members Posts: 1,080 Joined: 22-April 03 From: Las Vegas, Nevada Member No.: 600 ![]() |
It's rated for 7000lbs and meets all US specs, it's actually made in Canada. I probably won't put my diesel truck on it, but for anything short of that it should be fine. The safety tangs are really beefy, and show no signs of wear after considerable use. I haven't been able to find out much about the manufacturer though. It's called a GOLDEC Model 70. The construction is first rate, and it's extremely heavy, but able to be moved via a cantilever wheel system, without a car on it of course. The over all height is 9.5 feet, and it lifts just a hair over six feet.
drew365 |
These are the good old days! ![]() ![]() ![]() ![]() Group: Members Posts: 2,004 Joined: 29-December 02 From: Sunny So. Cal. Member No.: 37 ![]() |
I decided to stick with the 2 post that I ordered. I guess I'm going to pull the wheels off the upper car everytime I store it. Ugh. Now I will have another spare set of wheels to move around. I think I had a curse put on me recently and am just realizing it, spare wheels keep multiplying.
Someone asked about ceiling height. I have 9'4" to the bottom of my rafters. My lift is an open top so it will stick up past the rafters and I'm just limited on how high I can go by the rafters. A 2 post with the cables crossing over at the top would not fit in my garage. |
aufaber |
Member ![]() ![]() Group: Members Posts: 190 Joined: 7-April 03 From: Huntington Beach, CA Member No.: 525 ![]() |
QUOTE(seanery @ Sep 11 2003, 09:52 AM) cool, are they safe? Well sure.. are the elevators in three or four story buildings safe? pretty much the same thing. Main downside is that you have to build them in into the floor. -Aaron G> |
ChrisReale |
Sleazy ![]() ![]() ![]() ![]() Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 ![]() |
I want a lift also. I realized it sucks getting under the car with the engine 8 inches away from my face everytime I need to do something. Oh well, I'll add it to the list (IMG:style_emoticons/default/smile.gif)
cha914 |
MUSR 8 - 5lug conversion done wed - drive 500miles thrus ![]() ![]() ![]() Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 ![]() |
I bet you could rig up some suspension limiting straps that you could put on while the car was on the ground and lift the car...that way the strap would take the load and you wouldn't have to take the wheels off every time you put it up...
just a thought. Tony C. |
Lo-Fi Version | Time is now: 7th July 2024 - 06:36 AM |
