BigDBass |
Dumb Question Champion ![]() ![]() ![]() Group: Members Posts: 1,438 Joined: 11-January 06 From: Chicago (south 'burbs) Member No.: 5,405 Region Association: Upper MidWest ![]() |
In my apparently endless search for the right 914, I've come upon decent candidates which I then discover have been carburated. I've basically treated that as "nothing to see here, move along", but.... what if one finds what is otherwise almost the ideal match in condition, price, color, original parts, location, except for lacking stock fuel injection?
References usually say just that it's an expensive proposition to convert back to if you manage to acquire the necessary parts. How difficult and expensive is this? What all is involved? |
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
It depends... carbs with a proper rebuild and a cam? Or just a set of carbs because the FI was a pain in the ass.....
Porsche Rescue |
Saving and Enjoying Old Porsches ![]() ![]() ![]() ![]() Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None ![]() |
I would never let carbs keep me from buying the right car at the right price.
It is not that difficult to convert back to FI and not too expensive if you are patient in finding a system. Best would be a complete engine (running if possible) which you could strip and sell the remains. That way you get all the pieces. The key is learning from the seller (with confidence) that the cam is stock. If not, you would have to replace the cam. In that case I would stay with the carbs until time for an engine rebuild. |
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
You can come see my car with Carbs. Not for sale though.
Duplicate my set up and you would be a happy camper promise. Bring money and lots of it. |
BigDBass |
Drat, the owner of my current prospect (that so far I REALLY like) that has me asking these questions has had the car a long time but paid for maintenance and, since he "thinks it has a carb" i doubt he knows if the cam is stock or not. |
lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
The chances are better than even that it has a stock cam in it. You have to completely disassemble the engine to change the cam, and few people do so because of the expense involved, esp. if they have to pay someone else to do it for them.
If the stock EFI comes with in the box of parts, even if it "doesn't work", then I'd certainly consider such a car. The usual causes for "EFI doesn't work" are fixable with a bit of patience and very little money. Often, it's something as stupid as one broken wire. If you're not afraid to learn how to do the necessary rewiring, or you're willing to pay for a new FI harness from Bowlsby, then swapping back to FI shouldn't be a big deal. That said, any car the PO swapped to carbs should be very carefully inspected, and you shouldn't take the PO's word for anything. A carb swap on an otherwise stock engine shows a lack of patience or sense on the part of the PO and/or his mechanic, or an unwillingness to spend more than the minimum amount of money to maintain the car, which doesn't bode well for the rest of the car. You're very likely to have to do quite a bit of maintenance on the car immediately to make up for shoddy maintenance work in the past. Count on doing things like replacing all of the suspension bushings, all of the wheel bearings, rebuilding brake calipers, etc. These are all things that are commonly ignored by people on the minimum maintainance schedule. |
SGB |
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States ![]() |
1) true 2) a carb swap on a properly prepared engine shows just the opposite. 3) This is prolly true for any car. I've got carbs with the right linkage, cam, manifolds, headers and exhaust. It is rock solid dependable, economical, and powerful too. |
street legal go-kart |
Miss Mari's slave ![]() ![]() Group: Members Posts: 437 Joined: 28-March 03 From: sierra nevada ,cali . Member No.: 490 ![]() |
Also unless the cam is some redikalus grind which the stock engine does not need anyways you can convert back to fi w/no problems.
The Black car has stock d-jet w/a moderate bump on the cam and runs better w/more tq than before. I also did a ton of flow bench work on the heads and don't think the cam alone would show the hp and tq results w/out the head work. Jus my 2-cts. JT |
lapuwali |
Agreed, and I left unspoken that carbs (plural) on a non-stock engine simply show the guy preferred carbs. No problem with that. On the "prolly true of any car", I say, "not necessarily". My '71 came to me with a crappy single progressive Weber, which ran like crap. However, the wheel bearings, suspension bushings, tie-rods, etc. had all been replaced recently. The PPO (the guy I bought it from had only had it for 18 months before a 912 caught his eye), had gone through the car and done quite a few things "correctly". Even though it was a '71, it had a later passenger seat that had adjustable seat rails nicely welded in, and a later backpad to match. It had been repainted with a middling paintjob. Basically, the PPO had treated the car well. The only thing the PO did was to remove the perfectly working D-Jet because he thought the wiring harness "seemed brittle", and stuck on that crappy Weber. The car was fortunate I got the car away from this guy, before he did any more damage. |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
"a carb swap on a properly prepared engine shows just the opposite." thats usually not the case with 914's as DPO refuse to "fix" Djet and swap in a carb or set of carbs as a "easy fix". Even mechanics swap carbs in cuz "they are soo much better than FI". Usually the mechcanic doesn't have the training or knowledge on how to fix Djet. or you have a mechanic butcher the Djet so it runs way too lean and a valve seat drops (See Blairs Black car). |
Rrrockhound |
Member ![]() ![]() Group: Members Posts: 192 Joined: 30-November 05 From: Delaware, OH Member No.: 5,213 Region Association: None ![]() ![]() |
If you haven't seen the car yet, don't assume it's got carbs just because the present owner says it does. Sometimes dealers who don't know any better assume the FI is a carburetor. It happened to me. |
MecGen |
8 Easy Steps ![]() ![]() ![]() Group: Members Posts: 848 Joined: 8-January 05 From: Laval, Canada Member No.: 3,421 ![]() |
Hi
I have always thought the same way, stock or nuthin. So what I did was I kept the origional motor, with the origional injection, then bought a complete engine, tin and accessories included, played with that one, went carbs and cam, liked it so much I kept it.... (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif) Looking back (14 years) this was a good thing to do ... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) My car is going for sale, and the extra selling point is the OEM equipment. I recommend this to anyone owning an antique car. Kinda gives a nice insurance policy if interest or market changes. If you buy a carbed 914, and want to go back to FI, you have to expect some seroius $$$ if you plan to buy part by part. My car is 90% stock, except the motor, I love the sound. performance, feel, of my Dells sucking my air out of the cab (open top, no rain gutter). I wouldn't go back. I think no matter wich way you go its a win/win situation. Its a 914. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) +Karma for your search Later (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) |
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
Depending on the car's engine size (ie 1.7,1.8, or 2.0), I may be able to help with an engine with the stock FI intact if you're interested. PM me, I'm right by O'Hare Airport.
Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
May I stir things up a bit?
KT |
BigDBass |
(IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) By all means, do. |
Trekkor |
First off, I've not seen any data that there are any differences between any of the motors that used d-jet, l-jet or factory dual Solexs.
I've seen stock cammed motors that run fantastic. ( beat me at the a/x, too ) (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) Carbs need an intial set-up and if the jets are wrong it will always run bad. Going back to F.I. isn't big $$$. You can buy my entire great running 2.0 with complete d-jet and exhaust for $1500. I like the raw feel and sound of carbs. The arguement that carbs are hard starting is just not something I'm experiencing here. If you find a really nice car and it has carbs and runs well...You buy it (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) KT |
SGB |
If my car had FI when I bought it, I don't think I would intentionally carburate it. But the FI was gone. It ran pretty well with stock everything except weber 40 IDA carbs. HOWEVER, after putting the proper cam in AND manilfold AND heat exchengers AND muffler, the difference was quite amazing. I've actually never driveb a 914 with fuel injection.
lapuwali |
The Euro 1.8s with Solexes ran a totally different tune than the US 1.8s with L-Jet. Much higher compression, for one thing. I wouldn't expect big differences in engine tune between D-Jet and L-Jet. AX isn't a power game, so carbs v. FI aren't really an issue. Getting good power and good drivability and good mileage is very difficult with carbs. You can have all three with EFI. |
wbergtho |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,314 Joined: 28-April 03 From: Roberts, WI Member No.: 623 ![]() |
Carbs or FI aside. If you look at the rest of the car for a moment and disregard what type of fuel delivery...and find a real nice rust free car...I'd be inclined to buy it for the right price. Let's be real here...914's are over 30 years old now. A rust free carbed 914 wouldn't scare me away by any means! If you really want the FI...buy the bits...and put it back on. The chassis is way more important than the fuel delievery system.
Bill |
mightyohm |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest ![]() ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) Rusty car with FI vs. rust free with carbs? Motors are swappable.
Lo-Fi Version | Time is now: 25th June 2024 - 07:46 PM |
