cold air induction?, ricers benefit would type iv or a six? |
alpha434 |
Mar 26 2006, 01:14 AM
My member number is no coincidence. Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains |
Accurately measuring the exact temperature isn't important. Measuring a difference is. The accuracy on the unit was +- 5deg. The accuracy of calipers are +- 0.002". But in the case of either, you will notice a difference between one measurement to the next. This isn't random. It indicates differences in sizes between one measurement to the next. Is one inch exactly one inch when checked with calipers? Maybe. Maybe not. Is the next part, that measured 1 thou bigger than the last part, 1 thou bigger? Yes. Unless you went out of your way to disprove that by purposly botching the measurements of either. Same for the temp probe. Is the inital temp exactly 95 deg? Maybe. Is the next reading, at 98deg, three deg hotter? Yes.
Jake Raby |
Mar 26 2006, 08:51 AM
Engine Surgeon Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
My arrangement also uses a "K" type thermocouple... I agree thatb temperature differences are the biggest thing that one should use when analyzing data, but to me 1 degree IS within the variance of the instruments being used to gather data and I'd write off the change.
If I can't make a change that nets at least a 5 degree difference, the effort was wasted. Jacking up the timing 6-7 degrees should make at least a notable change in the oil temps. Don't forget that tests require controls to be effective, unless you can monitor (and sustain) load and RPM there is no control with the test he completed. If his ignition timing test would have included EGT and AFR monitoring as well as oil temp the results could be more closely compared.... Thats why I have a 32 channel data logger. By no means am I doubting his work with this testing, because I know how much it sucks to do test work, share the data and then be questioned by the very individuals that you intended to assist. Thats the reason why I quit posting my test results and started charging for the data... |
alpha434 |
Mar 26 2006, 01:18 PM
Roger that, Jake. Actively applying the scientific process is tough when other people are involved. Nobody trusts anybody these days.
So... What do you think about a chambered FI plenum cooloed by liquid CO2? |
Air_Cooled_Nut |
Mar 26 2006, 04:28 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
My opinion: Well, I've seen/heard plenty of people make claims to improvements via their "testing" just to find out their "testing" was less than scientific. Not knowing how testing was done raises suspicion with me. Maybe I'm scarred from my Business Statistics professor (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) In the scientific community, having your results scrutinized and you able to back up the data is par. I basically have to do the same stuff when creating executive-level reports for my customers. Just because one may be an expert -- or have good intentions -- doesn't necessarily mean they're right. |
Maltese Falcon |
Mar 26 2006, 08:47 PM
Advanced Member Group: Members Posts: 4,819 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
GM and Mopar used cold air as options in the '60/ '70s. My '69 SS350 drove the 1/4 mile 3 tenths faster than my pals RS 350 w/o cold air. Both cars were identically mod'ed otherwise, and weighed within 20 lbs. of each other. On my 986 Boxster filter kits, the unit is located right in the airflow of the fender duct.
Marty Attached thumbnail(s) |
URY914 |
Mar 27 2006, 08:32 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 122,935 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I've been looking at fab'ing a scoop/engine cover. I'm still early in the planning stage, but it will stick out through the roll bar like this pic shows. I have been running it w/out anything over the engine and I know sooner of later somebody will fill a protest because I don't have a "hood".
Maybe I can get it to seal over the carbs and than I'll only run one air filter. But that seems like a lot of work. Keep it simple. If you look at my avatar and look at the pic below you can see how I want it to look. Attached image(s) |
Air_Cooled_Nut |
Mar 27 2006, 12:45 PM
I like the idea of a single intake for your race car, however (there's always those (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) ), all your induction noise will be funneled through it and at you! My good friend has a mid-engined Notchback roadster (no roof) and it used to have a scoop over the engine somewhat similar to what you're talking about but it was loud! Step on the gas and it was louder still! Yeah, initially it was great but on any road trip it became fatiguing and forget about holding a conversation.
Granted, your's is for a race car (which will make even MORE noise) but still...do you really need all that extra noise in your right ear? Maybe if you placed it off-center, more to the right of the car? Just something to consider. |
Dr Evil |
Mar 27 2006, 12:58 PM
Send me your transmission! Group: Members Posts: 23,030 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Here is a pic I found for the fun of it.
URY914 |
Mar 27 2006, 01:03 PM
Good idea. I thought about locating it off-center away from my head a little bit. I would think with a full face helmet and if I need to, I'll put ear plugs in that I would be OK. I only need to put up with it for a few minutes at a time. |
Maltese Falcon |
Apr 15 2006, 02:19 PM
This is the MR 2 that I saw on the street, nicely done in fiberglass L and R sides. I've also seen them on another car still in primer (ricer style) , so these are more than likely mfg'd and sold in speed shops in San Gabriel Valley. Dedicated fit to the MR2 though...anyone handy in F'glass (Morphen Spectra) could make these up (IMG:style_emoticons/default/biggrin.gif)
Marty Attached image(s) |
Maltese Falcon |
Apr 15 2006, 02:21 PM
nuther from the rear angle. I'm sure that it gets some cold stuff in there.
URY914 |
Apr 16 2006, 05:39 AM
Looks kinda a stupid to me 'cause the intakes don't or bearly go above the roof line and the openings are so small. But I realize with the ricer crowd it's looks first, function last.
Now if you're going to aiir to the engine you need a SCOOP like this.... Attached thumbnail(s) |
redshift |
Apr 16 2006, 06:40 AM
You guys are IDIOTS!
Many of you removed your A/Cs... FOOLS! DPD air injection, YO! M |
Qarl |
Apr 16 2006, 09:25 AM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Elise air intake snorkel is right there on the side!
DNHunt |
Apr 16 2006, 04:16 PM
Here's my take on it. It seems to help a bit when I watch the intake temp but, I can't feel any difference
dlo914 |
Apr 16 2006, 04:24 PM
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
Brando |
Apr 16 2006, 04:41 PM
I think I'm going to find an intercooler of some sort that has the same diameter ports as my intake boot (between the AFS and Plenum), run it right under the decklid grille (a-la 930 style). Or better yet, in front of the cooling fan with a shroud made up around it... Forcing air through the intercooler. The fan is nothing but a huge vacuum...
Lo-Fi Version | Time is now: 21st September 2024 - 06:47 PM |
