Aluminum Pedal Boards, Replace your rotting one! |
Engman |
Mar 17 2004, 03:29 PM
Zoisite Group: Benefactors Posts: 1,349 Joined: 25-March 03 From: New Albany, IN Member No.: 475 |
Yes - I have several on hand. Sent you a PM with the info.
Thanks M |
a914guy |
Jun 6 2004, 07:48 AM
914 Master Group: Members Posts: 95 Joined: 25-December 02 From: Allen, Texas Member No.: 11 |
Hi Mark - :Bulk order..... (IMG:style_emoticons/default/biggrin.gif)
I'd like five! Four black, one uncoated. Yeller will get one, the Palo Alto project another, my "never ending six racer" project the third and the remainging two for gifts. Drop me a note and we'll figure out the total cost and shipping details. Rich |
Engman |
Jun 7 2004, 05:55 PM
Sent you a PM and dropped the four off at paint today. Will get back tomorrow.
M |
goobu |
Jun 27 2004, 05:26 PM
Newbie Group: Members Posts: 26 Joined: 17-June 03 From: New Jersey Member No.: 836 |
Does this actually save any weight? or is just there for replacing rotting old boards?
Engman |
Jun 27 2004, 06:09 PM
QUOTE(goobu @ Jun 27 2004, 03:26 PM) Does this actually save any weight? or is just there for replacing rotting old boards? Wood is always lighter than a same size piece of aluminum. That being said these are slightly heavier than the wooden one. I make the lightest ones available anywhere at 2.4 lbs. The wood ones wieght in at about 1.6 lbs. Now to the second comment on these being just for replacing rotting ones. These eliminate the flex in the board when you apply the clutch and it hits the stop or the accelerator stop. (not so much with the accel.) I originally made one and replaced my wood board (which was in really good shape). I noticed a distinct stop of the clutch which was not there before I did this. The bottom line - a good wood board will work fine but will have some give. This can (depending on your clutch cable adjustment) strech or pull the clutch tube out of the tunnel over time. The aluminum boards do not do this. M |
dflesburg |
Jul 7 2004, 11:57 AM
Senior Member Group: Members Posts: 1,722 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
I sent an email and got no reply.
Are these all gone? |
seanery |
Jul 7 2004, 07:09 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
Mark mentioned on another post that he will be on vacation or business out of town for a while.
Engman |
Jul 10 2004, 03:24 PM
Iam BACK! 1700 mile trip to visit my mom and brothers.
Emails and PMs sent to those inquiring. M |
beckdahl |
Jul 16 2004, 06:38 AM
Newbie Group: Members Posts: 5 Joined: 1-March 04 From: Ohio Member No.: 1,735 |
Mark,
Got mine today. Thanks for the quick response. It looks awesome. (IMG:style_emoticons/default/smilie_pokal.gif) MB |
Engman |
Jul 16 2004, 07:27 AM
Great! It was painted this week too!
M |
lapuwali |
Dec 13 2004, 04:16 PM
Just wanted to say I'm another happy customer, but for the short-run of 911 boards you made. Installed the driver's side board in my early 912 last night after a pedal cluster rebuild, and it's a great fix for an old, rotting wood board. I'd say you'd do well to make more of the 911 boards.
My only comment would be that the board is just a bit thicker than the wood board, and getting the nut on the retaining bolt was impossible until I dimpled the retaining plate a bit. However, this is a '67, so it's possible the very early cars had thinner boards. Certainly, the board I pulled out was very thin (and felt like it was made of balsa wood or something). |
Engman |
Jan 5 2005, 09:54 PM
Interesting. I will keep that bit of info in mind, but the boards I used to duplicate from were about the same thickness.
I do have 1 set of the early 911 boards in stock - more coming. M |
TimT |
Apr 25 2005, 04:53 PM
Im interested in a 911 board, just one question though? why is the 911 board $35 plus expensive than the 914 board?
seanery |
Apr 25 2005, 04:59 PM
have you seen the crazy bends those 911 boards have? (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
Engman |
Apr 25 2005, 05:03 PM
Its a lot larger! And it requires more time to laser cut. And it has a nasty form put into it (any bend in aluminum CAN be nasty - you really have to know what bend radius and angles to use). Those three factors are the reason for the price difference. M |
RoadGlue |
May 11 2005, 07:13 PM
Sonoma County Gear Head Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California |
Woo hoo! My pedal board arrived today and it looks like it's going to work great. My only "gripe" is that the edges weren't really de-burred. Not a big deal, as I don't mind the extra work, but could be an issue for others. The edges are sharp!
Question - If I wanted to paint the board black myself in the future, would powder coating work? I'm not sure if you can powder coat aluminum as it's not really conductive. Thanks for making this quality part available at such an affordable price. |
Engman |
May 11 2005, 08:56 PM
Wow - musta missed that one - I have been real busy with work - but that is no excuse. Send it back to me and I will pay the postage both ways and take care of this. I did change the way these are processed to eliminate the laser slag and that may be some of the issue.
Aluminum can be real tough to paint. I am fortunate to have access to an ecoat system with a 10 stage wash system. The secret to painting aluminum is surface preperation. Specifically an iron or zinc phosate pretreatment with a sealer coat. If you have a powder coater in the area with a good cleaning system - they should be able to do this. Ask first - some do not like the interaction with the phosphate bath. M |
RoadGlue |
May 12 2005, 02:01 AM
It's really not a big deal for me to clean up the edges, but I really do appreciate your offer. I brought it up mostly as an FYI. Thanks for the painting info too! Best, |
stateofidleness |
Sep 28 2007, 12:48 PM
Senior Member Group: Members Posts: 810 Joined: 1-September 07 From: Canyon Lake, Texas! Member No.: 8,065 Region Association: None |
just wondering if these are still available?
Engman |
Sep 28 2007, 01:14 PM
Yep -pm or email me.
M |
Lo-Fi Version | Time is now: 28th November 2024 - 03:40 AM |
