thesey914 |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 ![]() ![]() |
QUOTE(Eric_Shea @ Oct 26 2003, 07:14 AM) This will probably be the last post on this subject (I can hear the collective sigh of relief). (IMG:style_emoticons/default/laugh.gif) This is the best thread I have followed in ages....The greater technical content the better. I reckon this qualifies as classic thread status |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Very well done and quite inspiring. Yes, a classic thread.
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,655 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
Curious: anybody else do the eBrake conversion and whether there’s an alternative
waltonsm |
Member ![]() ![]() Group: Members Posts: 93 Joined: 27-June 14 From: United States Member No.: 17,561 Region Association: Pacific Northwest ![]() ![]() |
Curious: anybody else do the eBrake conversion and whether there’s an alternative On my build I used boxster hubs, brakes and e brake hardware. Pics of the trailing arm fab are here in post 50: http://www.914world.com/bbs2/index.php?sho...6435&st=40# |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,781 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Curious: anybody else do the eBrake conversion and whether there’s an alternative Jim I seem to remember a member on here welded on brackets and ran Wilwood handbrake calipers,these are fairly small units and it looked like a tidy solution. I liked this as another option and possibly easier than the 911 setup which I have. I found out to my displeasure and expense the PO had fitted this system without the weld on shoe retainers ,went for a drive to test h/brake and demolished the backplate and both shoe retainers and springs on one side (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/chair.gif) ,used parts for these are hardly cheap but atleast I was able to repair the backing plate but was still fairly pissed off. |
Retroracer |
Senior Member ![]() ![]() ![]() Group: Members Posts: 636 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest ![]() ![]() |
Curious: anybody else do the eBrake conversion and whether there’s an alternative Jim - yes, FWIW. Done with a Carrera vented rear set up. I used the Tangerine Racing kit for modifying the arms + handbrake cable routing - worked out nicely and retains the stock cables. - Tony |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,811 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Curious: anybody else do the eBrake conversion and whether there’s an alternative Jim - yes, FWIW. Done with a Carrera vented rear set up. I used the Tangerine Racing kit for modifying the arms + handbrake cable routing - worked out nicely and retains the stock cables. - Tony The tangerine kit is the way to go. Weld on a couple little bits and use your stock cables. It’s already developed so you don’t have to experiment. That being said, if you have a narrow body four, I would stick with stock rears. |
914GTSTI |
Member ![]() ![]() Group: Members Posts: 270 Joined: 16-September 07 From: Glendale AZ Member No.: 8,123 Region Association: None ![]() |
Is their a list of parts when going with the Tangerine Racing system ? Rotors, calipers ?
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,171 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Holy mother of thread necromancy!
(IMG:style_emoticons/default/blink.gif) Almost 20 years ... (IMG:style_emoticons/default/unsure.gif) |
The Double S |
Member ![]() ![]() Group: Members Posts: 93 Joined: 8-October 19 From: Upland, CA Member No.: 23,545 Region Association: Southern California ![]() |
Is the square bolt pattern on the backing plates the same for all pre-1989 non-turbo 911s?
I believe so.
73-914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 610 Joined: 24-April 10 From: Albany UpstateNY Member No.: 11,651 Region Association: None ![]() ![]() |
Holy mother of thread necromancy! (IMG:style_emoticons/default/blink.gif) Almost 20 years ... (IMG:style_emoticons/default/unsure.gif) Glad you said it, I was thinking the same thing (IMG:style_emoticons/default/agree.gif) |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,224 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Curious: anybody else do the eBrake conversion and whether there’s an alternative Jim I seem to remember a member on here welded on brackets and ran Wilwood handbrake calipers,these are fairly small units and it looked like a tidy solution. I liked this as another option and possibly easier than the 911 setup which I have. I found out to my displeasure and expense the PO had fitted this system without the weld on shoe retainers ,went for a drive to test h/brake and demolished the backplate and both shoe retainers and springs on one side (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/chair.gif) ,used parts for these are hardly cheap but atleast I was able to repair the backing plate but was still fairly pissed off. The late Wes Hildreth did this for a 914 owner named Mike Floyd ( @old914dog ). It did not work out well. Setting the park brake with the rotors hot resulted in the pads sticking to the rotors, and it took a hammer and some pounding to get the park brake to release. The 911 style park brake is the way to go. |
jim_hoyland |
Any info on the Wilwood electric parking brake kit ?
https://www.wilwood.com/Calipers/CaliperLis...Parking%20Brake Attached image(s) ![]() |
Lo-Fi Version | Time is now: 2nd April 2025 - 11:37 PM |
