rustoration progress |
nomore4 |
Sep 14 2003, 08:02 PM
Member Group: Members Posts: 106 Joined: 15-April 03 From: Northfield, NJ Member No.: 576 |
Spent the most of my 9-14 under my 914 grinding welds. I ended up replacing the entire bottom of the long. from the suspension console to past the jack post. With a little more work I'll be putting the floor back and starting the other side.
joe this is the start on the outer long. Attached image(s) |
nomore4 |
Sep 14 2003, 08:03 PM
another:
nomore4 |
Sep 14 2003, 08:04 PM
inner:
elmonte |
Sep 14 2003, 08:15 PM
Member Group: Members Posts: 225 Joined: 31-March 03 From: Danville.ca Member No.: 499 |
Nice surgery Doc (IMG:style_emoticons/default/smash.gif)
mazda |
Sep 14 2003, 08:29 PM
Newbie Group: Members Posts: 6 Joined: 31-August 03 From: upstate SC Member No.: 1,097 |
Joe, I am about to start the same job with near identical rust involvement. How much of the rear quarter panel did you have to get to the rust?
Can it be done from the inside with the engine removed? THanks, Paul |
nomore4 |
Sep 14 2003, 09:05 PM
Hi Paul,
This is my first attempt at a good rust repair. This is a scary spot to start digging. The frame 2 layers here and any visible rust is only the tip. Removing the floor and peices of firewall along with a more complicated shape made the inside more work. If you need to work above the jack post on the outer then a peice of the door sill, door jamb, and peice of the fender need to be removed. Post some pics for a better opinion. joe |
Jeroen |
Sep 15 2003, 04:19 AM
Hey Joe,
Very good looking repairs!!! cheers, Jeroen |
nomore4 |
Sep 15 2003, 06:59 PM
Today I added a rib to the bottom to match the factory seam. Hope to button this side up this week.
joe Attached image(s) |
Jeroen |
Sep 15 2003, 07:29 PM
nomore4 |
Sep 15 2003, 07:51 PM
They don't offer much cover from splatter (IMG:style_emoticons/default/blink.gif) My ankle's are cooked (IMG:style_emoticons/default/sad.gif)
joe |
redshift |
Sep 15 2003, 08:00 PM
Godspeed d00d, that is quite a repair you have going!
M |
Aaron Cox |
Sep 15 2003, 08:49 PM
QUOTE(nomore4 @ Sep 15 2003, 06:51 PM) They don't offer much cover from splatter (IMG:style_emoticons/default/blink.gif) My ankle's are cooked (IMG:style_emoticons/default/sad.gif) joe wear the hightop versions! lol- (IMG:style_emoticons/default/lol2.gif) |
Lo-Fi Version | Time is now: 5th October 2024 - 01:53 PM |
