OEL light -OPINIONS NEEDED-, 20 miles on my motor |
redshift |
Sep 15 2003, 05:49 PM
The OEL light flickers where idle should be.
It's .5qt over. I have to put 80 miles on her this PM, I don't want to roll til I have opinions. It's setup WAY rich. M |
Jeffs9146 |
Sep 15 2003, 05:52 PM
I had the same problem a week ago! I went out and purchased a mechanical pressure gauge and installed it! There was plenty of pressure so it is the sender that was bad!
Jeff Attached image(s) |
Jeffs9146 |
Sep 15 2003, 05:53 PM
The gauge!
Jeffs9146 |
Sep 15 2003, 05:54 PM
Keep in mind the photos are of a 6 so it will be a bit different on a 4! It cost me $19.99 to check it!
Jeff |
redshift |
Sep 15 2003, 06:06 PM
Well..
I am worried, I'll just hold it off idle, and let Crumley deal with it in the AM. "Flicker, flicker OEL light, how I wish you'd go out tonight..." Wish me luck #2! M |
cgnj |
Sep 15 2003, 06:07 PM
Senior Member Group: Members Posts: 634 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
Tom Perso |
Sep 15 2003, 08:37 PM
Crazy from the Cold... Group: Members Posts: 647 Joined: 8-August 03 From: Kalamazoo, MI Member No.: 1,003 |
Well, it depends where your idle is set at.
800rpm and with the oil hot, yes - it can flicker at idle. Also, it depends what weight oil. 30wt? You bet. My motor gets pretty low pressure at idle when she's nice and hot. My friends 2056 with a 30mm T1 pump will have it's oil light flicker at idle. Blip the throttle and it goes out - that is normal. What wieght oil are you running again? Tom |
redshift |
Sep 15 2003, 10:01 PM
30wt, non-detergent, broke in cam today, and she has 83 miles on her.
Yeah, @ 1000 and under, sick. (IMG:style_emoticons/default/smile.gif) This motor sounds like it has a motor hidden in it, unlike the first, which sounded like a warp core going critical. Thanks for all the stuff, I have to get over the paranoia of losing the first motor, I am sure I will sleep better. M |
redshift |
Sep 15 2003, 10:11 PM
QUOTE(Jeffs74~914 @ Sep 15 2003, 07:54 PM) Keep in mind the photos are of a 6 so it will be a bit different on a 4! It cost me $19.99 to check it! Jeff I am looking for a combo to get press/temp in the dash right now. I am scared without it, and I'll bet anal with it.. Jees.. $20 sounds... inexpensive.. (IMG:style_emoticons/default/smile.gif) M |
Jeffs9146 |
Sep 16 2003, 09:27 AM
Yes, the gauge was a cheep one! I just wanted to test the pressure! I plan on doing something like Kellzey!
Read: Gauge Combo Jeff |
redshift |
Sep 16 2003, 02:05 PM
QUOTE(Jeffs74~914 @ Sep 16 2003, 11:27 AM) Yes, the gauge was a cheep one! I just wanted to test the pressure! I plan on doing something like Kellzey! Jeff You plan on doing 'something' like Kellzey? Do what he didn't do! (if you can find something he hasn't done!) (IMG:style_emoticons/default/smile.gif) Maybe seek professional help? HE'S CRAZY! M |
Jeffs9146 |
Sep 16 2003, 07:52 PM
john rogers |
Sep 16 2003, 09:19 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
I use two senders, one for the light and a second for the gauge. The oil light is a BIG red one but I guess I am a little paranoid though....
Qarl |
Sep 16 2003, 09:27 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
-P- |
Sep 16 2003, 09:40 PM
P-Factor Group: Members Posts: 207 Joined: 1-July 03 From: Dallas, TX Member No.: 873 |
QUOTE(kellzey @ Sep 16 2003, 09:27 PM) Karl doesnt hold back and gives everything 110% and I respect that. He is an inspiration to us all. |
redshift |
Sep 16 2003, 10:18 PM
QUOTE(-P- @ Sep 16 2003, 11:40 PM) Karl doesnt hold back and gives everything 110% and I respect that. He is an inspiration to us all. Damnnit! He's giving you free parts, isn't he!? Money? Letting you touch his car? Have to admit, he is cute, who is that holding him in his avatar? (IMG:style_emoticons/default/smile.gif) M |
Lo-Fi Version | Time is now: 5th October 2024 - 01:48 PM |
