New Wheels & Tires For The Street!, pics |
Joseph Mills |
Apr 20 2006, 01:04 PM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
I ditched the 7 & 8" - 15 fuch replicas and went with 7" - 16 oem fuchs all around. Someday I'll need to have them polished.
I'm also trying out the new Hankook Ventus RS-2's. They are supposed to be similar to the Falken Azenis in performance and wear, but a bit less expensive. I'll be doing a 400 mile plus road trip this weekend on the Talimina tour and 120 miles of it will be on some great roads to see what these tires are capable of. (IMG:style_emoticons/default/driving.gif) some pics... Attached image(s) |
Aaron Cox |
Apr 20 2006, 01:13 PM
looks great! did you space the rears out?
seanery |
Apr 20 2006, 01:15 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
(IMG:style_emoticons/default/thumb3d.gif) Lookin' good Joseph!
Apr 20 2006, 01:19 PM
Resident German Group: Admin Posts: 41,699 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Joe Ricard |
Apr 20 2006, 01:33 PM
DAmn it
I am still waiting for availability for my size. 225/50-15 I want a full report of how them tires perform. |
Aaron Cox |
Apr 20 2006, 01:36 PM
RS2's are 3 bucks cheaper than azenis 615's in 205/50 15 at edgeracing.com
75 vs 78 |
Joseph Mills |
Apr 20 2006, 01:38 PM
looks great! did you space the rears out? Thanks guys! (IMG:style_emoticons/default/smile.gif) I have no spacers yet. But they need it. I have some 1/8th spacers loaned to me. I'm going to use them as a template and see if I can just fab some up. I think my studs are long enough for a 1/2" spacer. Are there any guide lines on this? Would this be acceptable at a DE event? .. |
Apr 20 2006, 01:42 PM
think my studs are long enough for a 1/2" spacer. Are there any guide lines on this? Would this be acceptable at a DE event? open lug-nuts and at least 8 full rotations on the nut, if i recall correct ... (IMG:style_emoticons/default/smile.gif) Andy |
Eric_Shea |
Apr 20 2006, 01:49 PM
PMB Performance Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE Are there any guide lines on this? Would this be acceptable at a DE event? PCA says 'the amount extending past the open nut should be equal or greater than the width of the stud' (14mm -or- 1/2" past the end of an open nut) |
Joe Ricard |
Apr 20 2006, 02:11 PM
QUOTE Are there any guide lines on this? Would this be acceptable at a DE event? PCA says 'the amount extending past the open nut should be equal or greater than the width of the stud' (14mm -or- 1/2" past the end of an open nut) Thats just crazy, can a mechanical engineer PLEASE explain how 1/2" of thread (which doesn't contact anything) add to the strength of a fastener? I run Ball end open lugs on my wheels so I wanna know. What does PCA say about closed nuts? as in Porsche alloy (light as a feather) lug nuts? |
Apr 20 2006, 02:15 PM
What does PCA say about closed nuts? as in Porsche alloy (light as a feather) lug nuts? they say they're fine as long as you don't run any spacers ... stock studs and no spacer, closed alloy is fine. custom studs and/or spacers, open steel nuts so they can verify you got enough thread on there ... i never had any problems passing tech with just 2 or 3 threads showing on a open lug nut ... (IMG:style_emoticons/default/smile.gif) Andy |
Eric_Shea |
Apr 20 2006, 03:23 PM
Joe, I think they just want a visual at tech and like Andy said, it's for special studs or spacers. I've done many DE's and auto-x's with stock alloy lug nuts.
Joseph Mills |
Apr 20 2006, 04:10 PM
stock studs and no spacer, closed alloy is fine. custom studs and/or spacers, open steel nuts so they can verify you got enough thread on there ... i never had any problems passing tech with just 2 or 3 threads showing on a open lug nut ... (IMG:style_emoticons/default/smile.gif) Andy So you're saying, for DE I can ONLY run my closed alloys if I remove the spacer. Is it safe to run spacers at a track? Maybe I'm thinking of the spacers that have their own studs built in for either conversion or wider spacers without resorting to fitting longer studs in your rotors. Will those pass inspection? .. |
Joseph Mills |
Apr 20 2006, 04:15 PM
RS2's are 3 bucks cheaper than azenis 615's in 205/50 15 at edgeracing.com 75 vs 78 I think the threads I read on the Hankooks were older posts before the price reduction on the Azenis. I seem to recall they had climbed up to somewhere around 115.00 each? Anyway, 80 bucks is about all I'm willing to pay for street tires. That is, as long as I'm having to pay 150.00 for AX tires... (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/ohmy.gif) .. |
Eric_Shea |
Apr 20 2006, 04:21 PM
Actually, I think you can run closed alloys for DE or Auto-X. I 'think' they 'require' open nuts for PCA Club Racing.
Air_Cooled_Nut |
Apr 20 2006, 10:48 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
... i never had any problems passing tech with just 2 or 3 threads showing on a open lug nut ... (IMG:style_emoticons/default/smile.gif) Andy From the books I've read on fastener technology, 2-3 threads is fine. Any more than that and the bolt is too long for the job (IMG:style_emoticons/default/smile.gif) I'm not a mechanical engineer, but I want to be one (IMG:style_emoticons/default/biggrin.gif) |
Apr 20 2006, 11:21 PM
So you're saying, for DE I can ONLY run my closed alloys if I remove the spacer. check your local rules, around here, yes ... also, around here, they *don't* like the bolt-on spacers that have their own studs ... (IMG:style_emoticons/default/dry.gif) Andy |
GTPatrick |
Apr 23 2006, 11:19 AM
Member Group: Members Posts: 245 Joined: 8-September 05 From: Memphis, Tn. Member No.: 4,768 Region Association: None |
Joseph Mills, . . . .
What size tires are you using on your 7x16 Fuchs ??? How much space is there between your tires and the edge of the fender wheel well rim curves ??? (IMG:style_emoticons/default/idea.gif) The 914 that I am buyig has 7x16 Fuchs with Falken tires on them but not sure of the tire size. the tires have barely enough room for my fingers to get in between the tires and the edge of the fender opening. Also, there is visual evidence of the tires rubbing against the edge of the fender opening from the upper edge of the opening onto the upper/outter edge of the tires sidewall. Flaring the fender seems to be the only solution so far but the P.O. tried it and the new paint cracked in several places when it was attempted. Thanks. (IMG:style_emoticons/default/type.gif) |
Aaron Cox |
Apr 23 2006, 11:23 AM
Joseph Mills, . . . . What size tires are you using on your 7x16 Fuchs ??? How much space is there between your tires and the edge of the fender wheel well rim curves ??? (IMG:style_emoticons/default/idea.gif) The 914 that I am buyig has 7x16 Fuchs with Falken tires on them but not sure of the tire size. the tires have barely enough room for my fingers to get in between the tires and the edge of the fender opening. Also, there is visual evidence of the tires rubbing against the edge of the fender opening from the upper edge of the opening onto the upper/outter edge of the tires sidewall. Flaring the fender seems to be the only solution so far but the P.O. tried it and the new paint cracked in several places when it was attempted. Thanks. (IMG:style_emoticons/default/type.gif) 7x16 on a "stock" - he has to have 205's on it. 215's or 225's are a stretch |
STL914 |
Apr 23 2006, 11:53 AM
Senior Member Group: Members Posts: 1,180 Joined: 22-October 03 From: O'Fallon, MO Member No.: 1,271 Region Association: Upper MidWest |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:46 PM |
