Bartlett 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest ![]() |
And I suppose that stock bright work seals the channel also ..... yaaassss ..... it certainly does Ollie. The stock seals don't seal. They are decorative only. And a lot of windows frames rust out. My comment was on the use of silicone. Other sealers are better to use. I have read here several times and from people in the windshield business that silicone is bad to use. |
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
Curious after 2 years how everything held up. I am about to disassemble and re-do the rear hatch on my 944 and will be using the paint for a cleaner look if it held up well. (IMG:style_emoticons/default/popcorn[1].gif)
zonedoubt |
Canadian Member ![]() ![]() ![]() Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada ![]() |
I currently have stock trim w/ a cracked windshield. After the new windshield gets installed I want to but the stock trim back on. Can the original clips still be used or do they have to come out when the old windshield is removed? I suppose it's a good idea to have some spares on hand when the new windshield is going in?
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,334 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
Original clips can be reused if they aren't broken. Should have 19 clips---as I remember.
Once, I replaced the clips and found the new clips chipped the paint around the inner edge of the holes. As a result, serious rust got started. Just something to watch for... |
Lo-Fi Version | Time is now: 26th June 2024 - 02:02 AM |
