3 Pages V < 1 2 3
> Corner Balancing a Twisted Tub ..., Adventures in Weight-Distribution Land ...
sean_v8_914
post Apr 23 2006, 11:55 PM
Post #41
Chingon 601
Good persistent german, good job. I think you need adjustable drop links...or srtaighten your tub (IMG:style_emoticons/default/wink.gif) did you read john Roger's psot about his corner balancing results?
did you shave off any time?
post Apr 25 2006, 02:02 PM
Post #42
Resident German
QUOTE(sean_v8_914 @ Apr 23 2006, 10:55 PM) *
can't tell. this was my first AX after i "downgraded" to a 1.7L ...
felt good. got within 3 secs of trekkor. biggest problem i had was that *tiny* gate right after the long right-hand sweeper.
my car is 10"+ wider than treks or nathans car and that gate only left me with 1" on each side and i was in 3rd at that point ...
3 out of 7 were clean, the other 4 times, i sent the cones flying ...
(IMG:style_emoticons/default/bye1.gif) Andy
Brett W
post Apr 25 2006, 04:06 PM
Post #43
What are your cross weight percentages? That is what really matters. Pulling your tub back into shape should not be that expensive. I had a chassis done for less than 400$ and another car done for $300.
byndbad914
post Apr 26 2006, 06:04 PM
Post #44
shoehorn and some butter - it fits
QUOTE(Brett W @ Apr 25 2006, 03:06 PM) *
I totally agree - $2K for a straightening!? That seems way outta whack, though I have never had a "tub" car straightened, I had a friend's subframe car tweaked back after I put a monster 383 in it and he bent the car first day out with it. I think it was $500 including welding in subframe connectors. That is a few years ago, so maybe $700 now with some inflation, but not $2K.
Seems like Pcar guys get screwed left and right. Just like when I was quoting out my tube chassis build for my 914 - everyone in the "Porsche" world was quoting $15K plus with no custom suspension and I am having a baja shop do the work with custom suspension stuff for MUCH less. No custom suspension quote was less than half the $15K!!! And frankly, tubes is tubes - and AJs welding is hands-down some of the best I have seen and witnessed first hand. Apparently a little (IMG:style_emoticons/default/smoke.gif) makes for some steady welds (IMG:style_emoticons/default/happy11.gif)
post Apr 26 2006, 06:22 PM
Post #45
Resident German
putting a car on a celette bench is not your normal body shop "pulling" ...
figure 8-10 hours times two worker-bees working the bench, normal shop-rate.
that is, if everything goes smooth. if not, more ...
plus renting the fixtures.
fixtures for the celette are about ~100 day.
that does NOT include stripping the tub ...
you do the math ...
(IMG:style_emoticons/default/smile.gif) Andy
PS: as i said, that would be your normal shop rate during normal biz-hours.
r_towle
post Apr 13 2007, 11:58 AM
Post #46
Custom Member
QUOTE(McMark @ Apr 22 2006, 01:38 PM) *
<!-- quoteo(post=664983:date=Apr 22 2006, 08:01 AM:name=r_towle) --><div class='quotetop'>QUOTE(r_towle @ Apr 22 2006, 08:01 AM) *</div><div class='quotemain'><!-- quotec -->
Would you mind showing us how you used scales...without the special racing scales....<!-- QuoteEnd --></div><!-- QuoteEEnd -->
Ghetto corner balance. It actually worked pretty well. Scales went up to 360+ lbs even though they were only rated for 300 lbs. $6 per scale on sale. (IMG:style_emoticons/default/wink.gif)
<!-- quoteo(post=664996:date=Apr 22 2006, 08:31 AM:name=rhodyguy) --><div class='quotetop'>QUOTE(rhodyguy @ Apr 22 2006, 08:31 AM) *</div><div class='quotemain'><!-- quotec -->
did you alter the corner balancing after the alignment? where did you make the biggest move? the adj perches, up front, or a combo?
The car was aligned when we started, now it's a little out of alignment. That the price you pay for night-before adjustments. The image Andy posted shows how obviously tweaked the chassis was. The left rear was above 600 lbs constantly, the front right was below 500 lbs most of the time and the front left/right rear were pretty stable and balanced at around 550 lbs. The left rear suspension pickup is probably tweaked downwards and the front right suspension is visibly tweaked upwards. So we made a lot of progress, considering the chassis.
Next step for Andy's car is the Celette Bench! (IMG:style_emoticons/default/wink.gif)
I have a few questions, cause I am about to do this.
did you do all four corners at once? Do I need 8 scales?
Or did you jack up and move each corner one at a time...
Or front then back...
Please let me know...I gotta go buy some scales.
Rich
McMark
post Apr 13 2007, 12:39 PM
Post #47
914 Freak!
You need 8 scales. (IMG:style_emoticons/default/wink.gif) Keep us posted on how it works for you.
Oh and you really should balance with your weight in the car. We balanced Andy's car with him in the drivers seat and me reading the scales.
John
post Apr 13 2007, 01:17 PM
Post #48
member? what's a member?
The only way to get an untwisted car to corner balance and have the chassis level is when the car is unloaded and on level ground.
When you add the driver's weight to one side, it will effect the way the car sits (when done, it will sit high on the drivers' side). If you want the car to look statically straight while parked, you do the corner balance while NO driver is in it.
If you want the best handling car, you corner balance with driver weight in the seat and the car set-up exactly like it will be run. The car may sit strangely (without massive springs), but it will be balanced and offer balanced handling.
just my $0.02
P.S. I only use 4 scales. My version of "Ruggles" scales offer a 4:1 ratio so a single 300# scale is enough per wheel.
McMark
post Apr 13 2007, 01:42 PM
Post #49
914 Freak!
What do you mean sit weird? (IMG:style_emoticons/default/blink.gif)
(IMG:http://www.914world.com/bbs2/uploads/post-179-1145755703.jpg)
r_towle
post Apr 13 2007, 01:47 PM
Post #50
Custom Member
the nice part is I have three boys, all my size...
So that will be a non issue...sit here, be quiet..
I also have loads of free weights if they are busy.
Rich
John
post Apr 13 2007, 08:10 PM
Post #51
QUOTE(McMark @ Apr 13 2007, 11:42 AM) *
Yes, Andy's car WAS twisted, and in that picture it does sit weird.
I would like to see a comparison with an AFTER pic of Andy's car after all the work has been done to straighten it an to make it go faster.
BTW, what did that car look like with ANDY sitting in it? Was it more level? (Just how much weight was in the Drivers' seat when it was corner balanced?)
post Apr 13 2007, 10:24 PM
Post #52
Resident German
QUOTE(John @ Apr 13 2007, 06:10 PM) *
all of my ~220 lbs in the drivers seat.
BUT, i run 250lbs springs, so the car actually doesn't move much when i get in.
even with me in the seat, it was still very much tweaked ...
John
post Apr 13 2007, 10:46 PM
Post #53
QUOTE(SirAndy @ Apr 13 2007, 08:24 PM) *
Let's see an after pic. Isn't it done YET??? (IMG:style_emoticons/default/poke.gif)
doper
post Apr 13 2007, 10:49 PM
Post #54
Gents,
If you ever get to the mid west I have real nice alignment bench I'd be happy to let you use for a beer or two ..... if it would help ....
later
doper
post Apr 13 2007, 10:51 PM
Post #55
Umm .. I should specify ... northern mid-west ... although I send a crap load of time in KC I'm 800 miles north ...
post Apr 14 2007, 12:12 AM
Post #56
Resident German
QUOTE(John @ Apr 13 2007, 08:46 PM) *
nope, it's not done yet ... (IMG:style_emoticons/default/chair.gif)
and the corner balance is the second to last thing on the list, right before the alignment.
(IMG:style_emoticons/default/smash.gif) Andy
3 Pages V < 1 2 3
- Lo-Fi Version Time is now: 24th November 2024 - 10:48 AM
