Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,177 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
After seeing this thread back in Sept, I ordered ther seals. Last night I went to install them and cant see where the small internal seal actually goes - even after looking the PET diagram. Do you have to pull apart the gear drive? Yes. There's a metal "ring" (for the lack of a better word) that is pressed in that you need to remove. The internal seal goes behind it. (IMG:style_emoticons/default/popcorn[1].gif) |
aharder |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,671 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region ![]() ![]() |
Thanks for pulling up the old thread (IMG:style_emoticons/default/type.gif)
I have the same problem but I have not been thinking about it cause I'm not close to putting the engine and tranny back in yet so I have not done the search. |
Scott S |
Small Member ![]() ![]() ![]() Group: Members Posts: 1,698 Joined: 30-April 03 From: Colorado Member No.: 633 ![]() |
Thanks Andy. I will go back at the thing tonight. Any tricks to removing the ring?
Thanks Again - (IMG:style_emoticons/default/beerchug.gif) |
Thanks Andy. I will go back at the thing tonight. Any tricks to removing the ring? It's been a while, if i remember correctly, i used some "hooked" pliers to get it out. It's on the big threaded end. If you look inside, you can see the inner seal sitting behind the metal ring. The ring is only pressed in and was fairly easy to remove on mine. (IMG:style_emoticons/default/chowtime.gif) |
andys |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None ![]() ![]() |
I don't know how useful this is, but the '75 that I bought (from an original owner) had an oil saturated passenger footwell and carpet. At the time when I stripped out the carpet, I was curious as to why there was oil in that area. It later occurred to me that transmission oil had weeped down the speedo cable and leaked where the cable connected to the CAT mileage counter box mounted in the footwell under the foam footboard.
Andys |
914_7T3 |
Please forgive me, I'm new to all of this! ![]() ![]() ![]() Group: Members Posts: 1,874 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California ![]() ![]() |
(IMG:style_emoticons/default/icon_bump.gif) For this thread as I need to replace these seals as well and having the correct part #s make it easy.
Lo-Fi Version | Time is now: 10th April 2025 - 07:13 AM |
