John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
I would guess one very long day or two days tops start to finish.
I would strip the interior backpad area (to keep it from catching fire), I would mark out where the welds go and grind back the paint to get to clean metal to weld to, locate the mount and weld it in. I would go back and wire-brush the welds, treat the area with metal-ready and POR-15 the welds. I would then go back and topcoat the POR and touch up any burned off paint. Then it is time for re-assembly...... |
Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
Do these kits come with instructions for exact locating on the firewall.
KT |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
John |
QUOTE Do these kits come with instructions for exact locating on the firewall. I made my own, so I had to figure it out. I don't know if the R.J. /Vellios or the PMS mounts have instructions. I would assume so, but it would be worth asking. |
Jeroen |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe ![]() |
Trek, no offense but...
How much convincing does a man need (IMG:style_emoticons/default/confused24.gif) These pics have been all been posted a gazillion times before When you asked when starting your conversion, pretty much everybody told you to get an RJ (or at least a bulkhead) mount I dunno, but the PMS bulkhead mount looks to be of the same contruction as the quickbar and seems to have the same ugly blobby welds And now you're worrying about how much work it is to weld in an RJ mount and if you're going to make it to your next AX? If I were you, I'd be worrying about how to keep my engine off the pavement... (IMG:style_emoticons/default/screwy.gif) |
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
We had a stripped race tub..... the weld, drilling etc...was two hours max.
dion9146 |
Member ![]() ![]() Group: Members Posts: 469 Joined: 16-May 04 From: Buckner, KY Member No.: 2,071 Region Association: MidAtlantic Region ![]() |
Trek,
Here is my RJ mmount in my previous car. I called Rich and he walked me through the measurements and installation...2 hours max (assuming engine out). I liked it so much I cut it out of this car and welded it into my new car also. There is no way in hell I would put one of those other cheap mounts after seeing RJ's work. This shouldn't even be a question. Go with the mob mentality, call Rich! (IMG:style_emoticons/default/thumb3d.gif) Dion Attached image(s) ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 03:30 AM |
