URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 125,833 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
ffff
Attached image(s) ![]() ![]() |
URY914 |
A/x
sww914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None ![]() |
My car, 4 years ago, an hour before it caught on fire and I had to repaint it.
Attached thumbnail(s) ![]() |
john rogers |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 ![]() |
CA Speedway
Attached image(s) ![]() |
john rogers |
Very dusty Palm Springs Historics 2005
9146R |
Member ![]() ![]() Group: Members Posts: 223 Joined: 28-September 04 From: alamo ca Member No.: 2,849 ![]() |
Infineon Turn 2
DanT |
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None ![]() |
AX#4
DanT |
nother
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
Will ya look at this.........
Sideways, one hand on the wheel, & waving at the cone chasers with the other. I always figured you track guys were smooth operators, but this....golly (IMG:style_emoticons/default/biggrin.gif) Attached image(s) ![]() |
DanT |
thanks JP (IMG:style_emoticons/default/smile.gif)
nebreitling |
Member Emeritus ![]() ![]() ![]() ![]() Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 ![]() |
beautiful shots, dan -- your car looks great...
my only thought -- are you getting enough suspension travel running it that low? |
DanT |
Not getting any bottoming at this point. Car has been on Sears point, BW and Th along with AX at Alameda with no suspension bottoming out.
I have had 4 914s and all of them have been this low....with the same basic suspension set up. Never had any issues with suspension travel. |
nebreitling |
I realize you have a lot of 914 experience. the car looks good -- very flat. I had my car as low as yours, but ended up raising it a bit when i measured how much (how little) suspension travel i was really getting. car actually feels better a little (not much) higher.
J P Stein |
gone
Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
in 7 at Sears.
KT Attached image(s) ![]() ![]() |
DanT |
Gee, Trekkor's car looks pretty low to me? (IMG:style_emoticons/default/confused24.gif)
Especially the front end. (IMG:style_emoticons/default/slap.gif) |
drew365 |
These are the good old days! ![]() ![]() ![]() ![]() Group: Members Posts: 2,004 Joined: 29-December 02 From: Sunny So. Cal. Member No.: 37 ![]() |
Gee, Trekkor's car looks pretty low to me? (IMG:style_emoticons/default/confused24.gif) Especially the front end. (IMG:style_emoticons/default/slap.gif) Maybe he was braking in the middle of the corner, which is why he is behind in the second picture. (IMG:style_emoticons/default/poke.gif) |
DanT |
No, Trekkor was not braking in the middle of the corner. I was instructing in his car when that picture was taken...he was passed because he has a stock 2.0L6 and Gregs car has a very nice 2.4L S motor that has a 8K redline. Greg was also shlepping around 185#s less weight, and Trekkor is still on the learning curve. (IMG:style_emoticons/default/smile.gif)
drew365 |
No, Trekkor was not braking in the middle of the corner. I was instructing in his car when that picture was taken...he was passed because he has a stock 2.0L6 and Gregs car has a very nice 2.4L S motor that has a 8K redline. Greg was also shlepping around 185#s less weight, and Trekkor is still on the learning curve. (IMG:style_emoticons/default/smile.gif) I was just kidding and poking a little fun at Trekkor. I certainly wasn't serious. |
DanT |
No, Trekkor was not braking in the middle of the corner. I was instructing in his car when that picture was taken...he was passed because he has a stock 2.0L6 and Gregs car has a very nice 2.4L S motor that has a 8K redline. Greg was also shlepping around 185#s less weight, and Trekkor is still on the learning curve. (IMG:style_emoticons/default/smile.gif) I was just kidding and poking a little fun at Trekkor. I certainly wasn't serious. I know...just giving a little background. It is always fun to kibitz about track stuff.(IMG:style_emoticons/default/biggrin.gif) But this time I was there.... (IMG:style_emoticons/default/blink.gif) |
Lo-Fi Version | Time is now: 2nd April 2025 - 02:06 AM |
