seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
This is what I have for the front. My car did not have bars installed before. I have a UTab kit as well as what you see here.
What do the 4 small tabs do? Attached image(s) ![]() |
seanery |
Rear. I have the mounting brackets coming.
-P- |
P-Factor ![]() ![]() Group: Members Posts: 207 Joined: 1-July 03 From: Dallas, TX Member No.: 873 ![]() |
I only count 2 bolts for the triangle mounts per side and wouldnt the drop links need bushings?
seanery |
complete bushing set is coming. New hardware replaces all old hardware except on bottom shock mount.
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
Are you going to use an inside bracket?
Jeff Attached image(s) ![]() |
seanery |
You're thread got me asking this question. I think that may be the only thing I'm missing.
I'll need to get some of those. |
Bruce Allert |
Hellions asleep ![]() ![]() ![]() ![]() Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest ![]() |
I made mine. Just found some steel the same thickness as the outside mounts & cut them with a jig saw then drilled the holes. The lower hole was the tricky one tho. Had to use AB epoxy to hold the nut to the plate while I screwed the bolt in from the fender well... and it worked (IMG:style_emoticons/default/beer.gif)
bruce |
JWest |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None ![]() ![]() |
The four small tabs go in the arm at the end of the bar to clamp it to the square end. This is a lousy drawing but they are #30:
seanery |
Does it go inboard, outboard or in the middle of part #28?
JWest |
Here is a better pic:
seanery |
so inside the #28 part. That makes sense. I was trying to figure out how that part didn't come off!
Van914 |
Van914 ![]() ![]() ![]() Group: Members Posts: 698 Joined: 5-January 03 From: Cincinnati, Ohio Member No.: 90 Region Association: Upper MidWest ![]() ![]() |
Sean, (IMG:style_emoticons/default/smash.gif)
Get busy its been 4 days since you picked up the sway bar. Get it in the car. Also there is a guy in New Albany, In. who is making the reinforcement plates. I will find his email for you. Van |
Jeff Bonanno |
il dottore ![]() ![]() Group: Members Posts: 421 Joined: 30-April 03 From: San Diego, CA Member No.: 636 ![]() |
seanery |
I ordered his plates as soon as James posted his.
I'll pick them up at Doc & Cy's on Saturday. Van, I picked up all the sway bar stuff (F & R) from the blaster today and dropped them off at the powder coater. I'm getting the brand & part # for the engine tin brad did for me and this stuff will match. |
Bruce Allert |
shor'du wish'd I'd've known 'bout dem plates fore I made mine. Geeze! dem's nice (IMG:style_emoticons/default/clap56.gif)
bruce |
seanery |
How long should the bolts be between the two "body mounts" ?
seanery |
I just got back from my local CAT dealer. Man, what an awesome vendor! (IMG:style_emoticons/default/smilie_pokal.gif) $3.81 worth of parts and they treat me like a million bucks. I got a couple pages from their parts catalog with part #'s and sizes I'll post later.
I went with 50mm for the above asked question. I hope that's big enough. |
Lo-Fi Version | Time is now: 26th June 2024 - 06:23 AM |
