Jwest driving lite flash kit, Where did I put the diagram! |
dinomium |
May 27 2006, 02:30 PM
Git on a chair son, all the good stuff is goin over yer head! Group: Benefactors Posts: 2,777 Joined: 2-January 03 From: Bremerton, WA Member No.: 74 Region Association: Pacific Northwest |
Okay!
So my toe still wont fit into my driving shoes (or steel toed work boots!) so I have decieded to bling out the green car. Installed and aimed yellowstar h4 headlights, removed wood dash kit for refinishing, swapped momo adapters so I have a horn, swapped out non narp flasher dial... I go to install the sooper kewl toy from jwest and I have LOST the directions!! Does anybody have a copy? Please email it to me rather than post. I tried the Jwest site, but got an autherization error, so since it is a long weekend... (IMG:style_emoticons/default/beer3.gif) |
736conver |
May 27 2006, 03:03 PM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
Send an email to James. I am sure he will respond quickly as he responded to me quickly when I had a question about my rennshifter
736conver |
May 27 2006, 03:05 PM
info@jwesteng.com
JWest |
May 27 2006, 03:44 PM
PM sent
dinomium |
May 27 2006, 11:34 PM
James is DA MAN! Thanks! I can now finish tearing apart a well running car!
(IMG:style_emoticons/default/biggrin.gif) |
dinomium |
May 29 2006, 01:50 AM
Has anybody else tried this on a 1970 car?
I am in PO wiring hell! Sumbuddy did some shade tree wurrin with only a spool of red thread! I pulled out his fresh air blower switch and all four wires were RED! The lites were broken and sad before I started so I dont know if they ever worked... The up side is the pass side is an old euro stock that takes the H3 bulbs! Sorta kewl... now, smart front of class keeds here is my question: When I replaced the white with blue wire from the fog relay to the F terminal on the headlight multi relay, it arched (key off) and now I only have hi beams? comments? besides the "dont do that again" type, TROY! (IMG:style_emoticons/default/beer3.gif) Fat tire makes fat boy not think kleerlee so I am waiting for directions suggestions advice also, if I jumper over from pole 87 to 30 the lites go on... (IMG:style_emoticons/default/confused24.gif) |
Dr Evil |
May 29 2006, 10:13 AM
Send me your transmission! Group: Members Posts: 23,034 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
If you had low before and now only have high, check your fuses. Lft/RT high and low beams all have their own fuses (4 of them) and you probably just blew yours.
1- High left 2- High right 3- Low left 4- Low right |
Dr Evil |
May 29 2006, 10:14 AM
Unless you already checked that stuff.....
dinomium |
May 29 2006, 01:44 PM
Thanks Mike, but the fuses are intact... Maybe I should saftey wire the fuses? HA!
I really think I have a MAJOR Previous Owner wiring nightmare that is going to require me redoing the headlight, fog light and fresh air blower circuit |
Lo-Fi Version | Time is now: 26th December 2024 - 03:26 PM |
