Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
ok.. now i understand. you torque them into the shoulder...
i pictured a threaded rod... with loctite holding it. sounds safe enuff (IMG:style_emoticons/default/smile.gif) AA |
DanT |
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None ![]() |
Yes (IMG:style_emoticons/default/smile.gif)
Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
MattR |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California ![]() |
i have had no problems with screw in studs. I also have a rear mounted oil cooler which works very good Bernie I've got one of those too! Its sitting in my driveway next to my turbocharged grasshopper (IMG:style_emoticons/default/ph34r.gif) |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
yep......the 130ftlbs of torque seems a little too much for the initial tightening of the studs. |
MattR |
The "proper" way to torque a stud is with a stud tool. Matco and SnapOn both have nice ones. But it will set you back more then a set of brake ducts... so I'd venture to guess a double nut would work. |
Mueller |
The "proper" way to torque a stud is with a stud tool. Matco and SnapOn both have nice ones. But it will set you back more then a set of brake ducts... so I'd venture to guess a double nut would work. kinda pricey is the word.....not worth it for 16 studs.... |
Lo-Fi Version | Time is now: 26th June 2024 - 09:55 AM |
