> another flair question...., over or under
crash914
post Jun 14 2006, 12:38 PM
its a mystery to me
I know its like boxers or briefs...
All the threads I have looked at show the fiberglass flair mounted over the sheet metal.
Why not mount it under? It looks like less blending will have to be done.
am I missing something?
fitsbain
post Jun 14 2006, 01:01 PM
Ask me if my car has rust!!!
The shape is all wrong to install from the bottom. Would have to cut lots of the fander to get it to sit right.
Joe Ricard
post Jun 14 2006, 02:18 PM
CUMONIWANNARACEU
I suppose you could if you think mounting on top like it was designed is TOO easy.
Dr. Roger
post Jun 14 2006, 03:23 PM
A bat out of hell.
hey crash,
check my thread HERE.
it's titled, "Sheridan fender fitment questions v.1.0, =-)"
cheers,
roger
bill and bynbad gave some great advice and pics... THANKS!
Dr. Roger
post Jun 14 2006, 03:28 PM
A bat out of hell.
another thread but a little more monotinous. <spelling?>
here
some say rivet it baby!!!
(IMG:http://www.patrickmotorsports.com/img/gallery/11410.jpg)
bob91403
post Jun 14 2006, 03:38 PM
Personally, I'd never add fiberglass flares to metal fenders. Either metal to metal, or, remove the fenders completely, and add complete fiberglass flared fenders from Rennsport. A lot less work, cuts weight, won't separate. And, if done correctly, you could sell your original fenders to someone who needs them, rather than cutting them up. Would end up costing less, and help some other 914 stay on the road. (IMG:style_emoticons/default/thumb3d.gif)
Mueller
post Jun 14 2006, 06:42 PM
914 Freak!
QUOTE(bob91403 @ Jun 14 2006, 02:38 PM) *
have you ever removed the 100+ spot welds to completely remove a fender??
once fender is completely gone where do you attach the new glass fender? (of course new brackets can be fabbed, but most 'glass fenders are not designed to completly replace the entire fender, only part of it...
as for the anti-'glass crowd, there are many installs that have been running for 10+ years with V8's or high strung /6 motors with no signs of seperation or pitfalls....
Crash.....in order to install the flare from the inside of the fender, one would have to a near perfect cut, too much steel removed and you'll have a huge gap, not enough material removed and the flare won't be flush to the fender....way, way too much work and trial and error...
jimtab
post Jun 14 2006, 08:16 PM
QUOTE(Dr. Roger @ Jun 14 2006, 02:28 PM) *
here
OMG that car is beautiful...it makes me wet....Roger is that one of yours.... (IMG:style_emoticons/default/wub.gif)
VaccaRabite
post Jun 14 2006, 08:28 PM
En Garde!
I love the riveted look for fender flare. If I ever flare mine, that is how I intend to go.
Zach
So.Cal.914
post Jun 14 2006, 08:39 PM
"...And it has a front trunk too."
Plus if you put it on the inside it would cut down on the well area and would not
accept as wide a tire and rim. What would be the point? (IMG:style_emoticons/default/huh.gif)
drive-ability
post Jun 14 2006, 09:28 PM
Where do you guys get the Sheridan body kits? (IMG:style_emoticons/default/smash.gif)
Aaron Cox
post Jun 14 2006, 09:30 PM
Professional Lawn Dart
QUOTE(drive-ability @ Jun 14 2006, 08:28 PM) *
ultimate914.com
crash914
post Jun 15 2006, 05:46 AM
its a mystery to me
the reason behind the question....I don't need that much room for a wider tire... Saving 1/2 inch in width would be ok.
My current fenders are shot. many blows with a 5 # sledge to make clearance for my 8.5" wheels... so no loss there.
It just looks like they would fit inside without too many issues...
besides, I like doing it the hard way..
Its time to take the car off the road for a few days, new shorter cylinder shims, new push rods, seal up my oil leak, install flairs, install new header...the list is endless....
Joe Ricard
post Jun 15 2006, 06:32 AM
CUMONIWANNARACEU
8.5" rims and big tires need ALL the fender you can get.
my Hoosiers have 1/2" outside and 1" inside with -1 degree camber.
Oh yea section width is 11.5"
and rivets rock (IMG:style_emoticons/default/mueba.gif)
Pompano Beach 914V8
post Jun 15 2006, 07:50 AM
I assume that what you are trying to acheive is a smooth trasition from flair to fender with the least possible work. I attached a Sheridan kit (with the help of a body man....a good one...) by using a two part adhesive. After it was glued on, the fiberglass was tapered into the existing fender and then finished with quality filler.
BTW this adhesive is strong stuff, I mean really strong stuff. The body guy droppped a glob on the concrete floor when he was gluing the flairs and didn't realize it. When this stuff was set he tried to chip it off and it ripped up a hunk of concrete! This junk is stronger than the steel or the fiberglass!
You are going to have to blend no matter whether the fiberglass is on the inside or the outside, so you might as well glue it on the outside (the way it was designed) and blend it.
crash914
post Jun 15 2006, 11:24 AM
its a mystery to me
I love the big duct tape tire look....
what happens to the 100 mph tape if you exceed 100 mph?
- Lo-Fi Version Time is now: 2nd January 2025 - 06:57 PM
