sixerdon |
Member ![]() ![]() Group: Members Posts: 466 Joined: 23-May 03 From: Dartmouth, MA Member No.: 731 ![]() |
Nice pictures Todd,
Two things of note. 1. Notice the wiring harness running along the floor of the trunk, up against the rear bulkhead where a lot of water can collect. Early models ran along the rear shelf. When was the change over? (Mine is like yours Todd) 2. Notice the aluminum rivets holding the white roof top storage bracket. Early models were fastened by 2 10mm bolts. When those brackets break on later cars, where do you get the rivets? When was the change over? Don |
tod914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 ![]() |
Not another rivet quest! Don, only 1 side on mine has the rivets, the other is bolts like you stated. I guess somewhere along the line one side was replaced.
sixerdon |
tod914 |
Right side plastic latch
sixerdon |
Tod, I checked my '76 parts car and my '75 and they have those rivets. Or are they? They can also be plugs. Whatever they are, I have never taken them off.
My '74 parts car has the 10mm bolts with a square nut welded to the backside of the engine bulkhead. That seems to be same with all the earlier cars. If your 10mm bolt is fastened to a removeable nut, then sometime in the past, the rivet (or plug) was drilled out to replace a broken clip. Is there anyone else who can add to this? Don |
tod914 |
Don, the rivets where drilled out and replaced with the bolts and nuts. I guess I get 1 demerit lol.
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
1. Notice the wiring harness running along the floor of the trunk, up against the rear bulkhead where a lot of water can collect. Early models ran along the rear shelf. When was the change over? (Mine is like yours Todd) I'm guessing it's a 75/76 thing because the rear shelf got blocked by extra braces with the addition of rubber bumpers. |
Pat Garvey |
Do I or don't I...........? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,900 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States ![]() |
Tod, I checked my '76 parts car and my '75 and they have those rivets. Or are they? They can also be plugs. Whatever they are, I have never taken them off. My '74 parts car has the 10mm bolts with a square nut welded to the backside of the engine bulkhead. That seems to be same with all the earlier cars. If your 10mm bolt is fastened to a removeable nut, then sometime in the past, the rivet (or plug) was drilled out to replace a broken clip. Is there anyone else who can add to this? Don (IMG:style_emoticons/default/boldblue.gif) Love it! New ground here! Don't know about the rest of you, but I'm bein edified! Attached image(s) ![]() |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Heck, I like looking at pics of RustyWa ole car. Can't say I am edified...what the heck is that?
Pat Garvey |
tod914 |
Better than being munsoned
Dion |
RN ![]() ![]() ![]() ![]() Group: Members Posts: 2,832 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region ![]() ![]() ![]() |
73' 1.7 (now with 2.0) same ol' trunk.
Attached image(s) ![]() ![]() |
Dion |
Still need marathon blue on the bottom. What is this number on the lower right corner in the boot?
Pat Garvey |
Still need marathon blue on the bottom. What is this number on the lower right corner in the boot? VERY nice trunk! Paint the bottom! Number in the RR corner is Karmann's production numer and does not necessarily run in sequence to final production. Looks good Dion! |
Dion |
Thank you Pat. I appreciate the compliment. Thanks for the info on the trunk #. Waiting for this humidity to drop so the gentleman who did the body work and paint can coat this area. Needed to repair some rust in the trunk edge/floor near the rt. tail-light. Cheers,Dion
Pat Garvey |
Thank you Pat. I appreciate the compliment. Thanks for the info on the trunk #. Waiting for this humidity to drop so the gentleman who did the body work and paint can coat this area. Needed to repair some rust in the trunk edge/floor near the rt. tail-light. Cheers,Dion Hear what your saying about the humidity! |
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,862 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Does everyone know that the chassis number is actually a code with embedded meaning about your 914?
Series9 |
Lesbians taste like chicken. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,446 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States ![]() |
Manufactured 3/05:
Leo Imperial |
Do you have to use so many cuss words? ![]() ![]() ![]() Group: Members Posts: 906 Joined: 29-November 04 From: 914 Roadshow - Glen Cove NY Member No.: 3,192 Region Association: None ![]() |
Manufactured 3/05: Not possible. They didn't offer the crossbar until 4/05. Please don't post false info in this forum (IMG:style_emoticons/default/mad.gif) |
boxstr |
MEMBER:PACIFIC NORTHWEST REGION ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest ![]() |
Here are a few rear trunk shots.
Craig Attached image(s) ![]() ![]() |
Lo-Fi Version | Time is now: 31st March 2025 - 05:10 PM |
