EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
Upon startup after the car sat for about 3 weeks, I noticed a bunch of fuel squirting out from the fuel pump area. Like lots. When a pump fails, is this normal? Why does the car keep running? My fuel lines are relatively new and were not leaking at all before.
Any ideas on where I can find a deal on 73 fuel pump?? |
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
Look at it before you buy a new one. Nut! You are almost as bad as me!
Fix it AFTER you figure out where the failure is. (IMG:style_emoticons/default/smile.gif) Mr. Paranoid-troubleshooter |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
QUOTE(cavwpguy @ Oct 6 2003, 07:58 PM) Upon startup after the car sat for about 3 weeks, I noticed a bunch of fuel squirting out from the fuel pump area. Like lots. When a pump fails, is this normal? Why does the car keep running? yes - the O-ring that sits between the 'pump' part and the 'electrical' part gets old, brittle, and breaks. common failure mode. the car keeps running because in a recirculating system, the pump is moving a lot more fuel than the engine needs, especially at idle. i have no clue on replacement parts but in the turbo-Ford-914 thread we remembered that MSD has a pump that appears to have similar specs to the T-IV pumps for less money. that is the extent of my knowledge on this subject, sorry ... |
ChrisReale |
Sleazy ![]() ![]() ![]() ![]() Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 ![]() |
I got an extra.....might help.
Lo-Fi Version | Time is now: 26th June 2024 - 04:19 AM |
