drive-ability |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 ![]() |
I have Polly bronze front bushings but have an alignment issue. The two points don't line up well. Its not bad but does bind a bit. Do these help ?
Self aligning bushing mount. |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
I guess I dont understand what is happening?
Do you mind explaining (the best your can) what is happening? B |
drive-ability |
I guess I dont understand what is happening? Do you mind explaining (the best your can) what is happening? B Here is a link to whats going on. Link |
Jeroen |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe ![]() |
before you go out and spend mega bux on these thingies try this:
before tightning the bolts of your front suspension, move the arm up and down a couple of times (disconnect shock @ the balljoint and remove the t-bar adjuster bolt) this will help align the parts then tighten everything down also make sure the front a-arm bracket is positioned as far back as the a-arm allows, otherwise your a-arm is able to move front/back I did this and had no issues with binding |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
those are a band-aid for a screwed up chassis.............
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,201 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
those are a band-aid for a screwed up chassis............. (IMG:style_emoticons/default/agree.gif) ask me how i know ... |
drive-ability |
those are a band-aid for a screwed up chassis............. (IMG:style_emoticons/default/agree.gif) ask me how i know ... (IMG:style_emoticons/default/agree.gif) I will disassemble everything and find out where the root problem is. There is not really much binding but I am going with needle barrings. The alignment needs to be right. Whats the best way to proceed? |
Brad Roberts |
It depends on what plane the arm binds.
If it is binding in a 2-3 inch range from parallel to the ground.. then play with the alignment. I learned to tighten everything down with the arm in the "flat" position. I dont care if it binds and the arm is hanging straight down. B |
drive-ability |
It depends on what plane the arm binds. If it is binding in a 2-3 inch range from parallel to the ground.. then play with the alignment. I learned to tighten everything down with the arm in the "flat" position. I dont care if it binds and the arm is hanging straight down. B Thanks Brad, That sure makes sense to me. Installing the Polly bronze made a difference compared to the urethane. I hope the needle bearings make as big a difference. (IMG:style_emoticons/default/smash.gif) |
Brad Roberts |
I installed a set of PolyB rears this past weekend.. I wasnt impressed. They work, but they dont hold a candle to the roller bearings.
The shaft for poly setup had to be hammered into place. The shaft for the roller setup will FALL out of the arm (IMG:style_emoticons/default/smile.gif) I'm sure the poly setup would work well, but never as good as the roller. B |
Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
NFL - not for long?
drive-ability |
I installed a set of PolyB rears this past weekend.. I wasnt impressed. They work, but they dont hold a candle to the roller bearings. The shaft for poly setup had to be hammered into place. The shaft for the roller setup will FALL out of the arm (IMG:style_emoticons/default/smile.gif) I'm sure the poly setup would work well, but never as good as the roller. B Good to here that about the roller bearings. I should have them by Wednesday. (IMG:style_emoticons/default/beerchug.gif) |
eeyore |
Senior Member ![]() ![]() ![]() Group: Members Posts: 889 Joined: 8-January 04 From: meridian, id Member No.: 1,533 Region Association: None ![]() |
Mueller |
I'm getting new pricing on the components this week....I've also been approached by a few people off-line that are willing to pre-purchase so that way the initial order should be covered and I'm not sitting on too much overhead. The problem I had in the past was that I'd charge the $3,000+ on my credit card for parts for a certain amount of kits and material and then once I sold a kit, I had a bad habit of NOT applying that money to my credit card (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/screwy.gif) I have now since seen the light (IMG:style_emoticons/default/smile.gif) I've also learned a few things about the manufacturing that is making things easier on me (paying someone else to do make some of the part as well as streamlining the process for the parts I do decide to make in house....it's all a learning experiance) |
turbo914v8 |
Member ![]() ![]() Group: Members Posts: 373 Joined: 26-July 03 From: Canada Member No.: 952 ![]() |
I'm getting new pricing on the components this week....I've also been approached by a few people off-line that are willing to pre-purchase so that way the initial order should be covered and I'm not sitting on too much overhead. The problem I had in the past was that I'd charge the $3,000+ on my credit card for parts for a certain amount of kits and material and then once I sold a kit, I had a bad habit of NOT applying that money to my credit card (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/screwy.gif) I have now since seen the light (IMG:style_emoticons/default/smile.gif) I've also learned a few things about the manufacturing that is making things easier on me (paying someone else to do make some of the part as well as streamlining the process for the parts I do decide to make in house....it's all a learning experiance) Well let’s get the ball rolling. I will pre purchase a set front and rear NOW. I suggest the rest of you jaw flappers anti up and do the same. We almost lost a great 914 product here let’s not let this happen again. Mike thanks for continuing to supply a great product. |
914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
Okay update please getting ready to buy Poly Bronzes if these are comming back onto market, I am ready , need front and rears?
So Mike whats the ETA looking like now? |
Lo-Fi Version | Time is now: 29th April 2025 - 01:19 PM |
