> Model Specific Information
6 Pages V « < 4 5 6
> Front trunks, Front trunks/boots - all years
smg914
post Jan 25 2013, 09:43 AM
Post #101
Sahara Beige Steve
QUOTE(ThePaintedMan @ Jan 25 2013, 07:04 AM) *
Hi guys,
I rarely stray into the originality section, given all the stupid things the PO did to my car - it'll never be original. However, I do appreciate all the information you have post and this section is very entertaining to read!
Question - my car never had the board over the spare tire recess in the front trunk. In fact, I don't even have a spare. I think I can probably cut some plywood to approximate the original piece, but I have no idea how it attaches or stays in position. It appears from the pictures that it rides on top of the curved support pieces at the front of the trunk, but what about at the back, at the trunk firewall? There are no obvious screws or mounts in my car to support the back of that board. Thanks for your help!
-George
Hey George,
That board just sits in there. Doesn't attach to anything. I will probably drive a 914 to the Daytona on TV get together on Saturday so you can look at yourself.
ThePaintedMan
post Jan 25 2013, 10:32 AM
Post #102
Sweet! (IMG:style_emoticons/default/cheer.gif) Looking forward to seeing you again Steve!
QUOTE(smg914 @ Jan 25 2013, 10:43 AM) *
Hi guys,
-George
Hey George,
Peashooter
post Jan 25 2013, 12:47 PM
Post #103
Here are the gray ones. Thanks for the info, I'll use the black pair.
Bill
Mhead
post Jan 9 2014, 12:18 PM
Post #104
Very early front trunk, notice no charcoal canister...Attached Image
vanlynch
post Feb 22 2017, 01:47 AM
Post #105
QUOTE(Johny Blackstain @ Mar 30 2007, 08:10 PM) *
what is that hose/line for & what does it connect to?
1970 Neun vierzehn
post Feb 22 2017, 06:05 PM
Post #106
vanlynch,
That hose appears to be line that connects the windshield washer bottle with the (unconnected) spare tire valve. The tire pressure (theoretically) pressurizes the windshield washer bottle to (theoretically) spray the windshield with washer fluid. The attached photos show that hose in the front trunk of my 1970/4.
Paul
TM_Corey
post Sep 8 2017, 06:23 PM
Post #107
Does the vertical carpet tuck under the rubber that runs the width of the top of the wall that separates the gas tank area and the spare tire area?
914Next
post Sep 10 2017, 10:33 AM
Post #108
QUOTE(TM_Corey @ Sep 8 2017, 08:23 PM) *
Yes. Here are a couple pics. This is original installation in my car.
brcacti
post Oct 16 2020, 08:01 PM
Post #109
1974 914 1.8
front trunk with carpet board taken out, windshield water system not hooked up to spare tire.
AndrewBlyholder
post Apr 18 2021, 10:55 AM
Post #110
When I have a chance, I"ll go digging...
I'm not sure if melamine is the correct term to be used...I borrowed it from this thread. But the stuff is that crappy pressboard cardboard stuff that breaks off in flakes.
I have the leftover parts from a 74..and from what was titled a 73 but may have been very early (since it had the doors without the sidebars)...I'm pretty sure that both of them had the non plywood crap.
A response from your local retired architect:
Melamine is not the right term. That refers to a version of particle board with a Melamine plastic coating used a lot in cabinets and signage where a good smooth finish is necessary.
What's in our cars is a type of particle board made from pressed sawdust/wood chips. It comes in may variations, depending on the exact texture of the wood particles and the amount of heat and pressure used to form it. Masonite is a common name brand for a version that used a lot of heat and pressure and was very hard and dense. A more generic term for that type is hardboard. The particle board used for cheap shelving is at the low end of that scale. The stuff Porsche used for the pedal boards is somewhere in the middle.
Stev914
post Dec 4 2024, 11:15 PM
Post #111
Hello all:
Searching this thread, I saw a dealer sticker like this one from my '72. What do the codes mean, and what does the printed text say (I can read most of it, but want to be sure).
Is this where these stickers were usually put?
Thanks!
Steve
1972 Porsche 914-4
914Next
post Dec 6 2024, 07:44 AM
Post #112
QUOTE(Stev914 @ Dec 5 2024, 01:15 AM) *
Hello all:
Thanks!
Steve
1972 Porsche 914-4
Can't say definitively but I think that is a sticker verifying the "HO" recall?
https://bowlsby.net/914/Classic/Recalls.htm
FlacaProductions
post Dec 6 2024, 09:19 AM
Post #113
That's correct - the HO campaign.
Stev914
post Dec 6 2024, 01:25 PM
Post #114
This forum is the coolest! So that HO sticker is from a 1977 recall. Great to know.
Thanks!!!
SR
6 Pages V « < 4 5 6
- Lo-Fi Version Time is now: 31st March 2025 - 05:11 PM
