> Engine Lid Problems, Enigne lid is tweaked when torsion springs are installed
davesclassicvws
post Jul 4 2006, 11:11 AM
davesclassicvws
I need help solving a problem. I have a 1973 914 I've been slowly restoring these past 6 months. the engine lid was missing the torsion springs when I bought the car and I went to install a set yesterday. When I install the springs the torsion pulls the hinge on the passenger side out of wack and the lid won't close properly. If I push on the outside edge of the lid I can force the lid back into position but the springs are putting to much pressure on the hinge assy.. How can i fix this? Any help would be appreciated.
lapuwali
post Jul 4 2006, 11:27 AM
Not another one!
It's quite likely the part of the hinge that's welded to the firewall is broken. This is a very common problem. The bracket sags, and this allows the lid to shift so it won't close anymore. You'll need to either get the bracket welded up, or replace the bracket entirely. Examine that bracket carefully, and you'll probably see cracks.
post Jul 4 2006, 12:11 PM
Resident German
QUOTE(lapuwali @ Jul 4 2006, 10:27 AM) *
newto914s
post Jul 4 2006, 01:57 PM
Make sure if you get it welded they weld it flush with no gap. Brought my car to a place to have them tack weld my hindge back(it pulled out a little while working under the hood) and they left a 1/4 in space. I didn't have the hood with me to test fit it. Then when I got home and put it on the gaps were all off. (IMG:style_emoticons/default/headbang.gif)
johannes
post Jul 4 2006, 05:49 PM
Club Porsche 914 France President
Region Association: France
Have the same problem.
The right hinge is loose and would need to be rewelded. For instance it hold the lid at the proper place but I had to remove one of the two springs.
I will fix that one day. (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif)
- Lo-Fi Version Time is now: 26th December 2024 - 06:47 PM
