fuel pump problems, HELP! |
72914S |
Oct 13 2003, 05:40 PM
love this shot Group: Members Posts: 1,290 Joined: 10-July 03 From: Pensacola,Fl. Member No.: 900 Region Association: South East States |
I can`t get any (3) of my fuel pumps to pump fuel. They run fine but will not pump.I took them apart and cleaned the faces,gear and the 5 pins,they had some crud on the working parts.The only thing that I can see that might be wrong is the plate,which way does the little notch on the space plate? top? bottom? left ? right? Barry (IMG:style_emoticons/default/confused24.gif)
Rusty |
Oct 13 2003, 06:33 PM
Wanted: Engine case GA003709 Group: Admin Posts: 7,943 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
72914S |
Oct 13 2003, 06:49 PM
all relays are good the pumps are running just not pumping? (IMG:style_emoticons/default/confused24.gif)
seanery |
Oct 13 2003, 06:51 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
are they backwards?
Oct 13 2003, 06:52 PM
Resident German Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(72914S @ Oct 13 2003, 05:49 PM) all relays are good the pumps are running just not pumping? (IMG:style_emoticons/default/confused24.gif) is it FI or carbs? if you get the hoses wrong on the FI pump, it won't do anything. they don't suck, just move the fuel. that's why they have to be mounted lower than the tank. Andy |
joea9146 |
Oct 13 2003, 06:59 PM
Senior Member Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None |
The pumps will also run Backwards if you reverse the negative and positive leads (IMG:style_emoticons/default/smash.gif)
Lotus914 |
Oct 13 2003, 07:07 PM
Newbie Group: Members Posts: 38 Joined: 10-October 03 From: bleak suburbia Member No.: 1,234 |
Crud in the tank? Never had mine apart, but I recall reading about some sort of filter sock deal in the tank that can clog. Try pumping fuel from a gas can as a test?
Dave |
72914S |
Oct 13 2003, 07:54 PM
did the gas can trick won`t suck fuel. just came in from the shop tested pump by squirting fuel in S port but when I put power to it fuel came out the S port not the D port? has any one had this pump apart ? there is a plate between the pump and the outlet cap and the hole is offset.does anyone know the proper postion for it? it is square but one side has an indent. (IMG:style_emoticons/default/idea.gif)
72914S |
Oct 13 2003, 07:55 PM
By the way this is a D-jet 2.0 type pump
72914S |
Oct 13 2003, 10:34 PM
(IMG:style_emoticons/default/clap56.gif) well I have two working fuel pumps ...it was the pressure valve (you know the the little silver cap thingy) they were stuck closed! a little PB BLASTER and a small screw driver,six years on the shelf is a long time. Now maybe on the road this week end.
Lotus914 |
Oct 14 2003, 01:24 PM
Congrats! - and nice melons.
72914S |
Oct 14 2003, 06:28 PM
Well the fuel pump is pushing 60+ psi .got it dialed in at 28 lbs .Now the injecters fail. new ones coming tommrow. SIX years is to long to have left them boxed up. Hope to have "Lil Red" up and running this week-end?
Lo-Fi Version | Time is now: 26th June 2024 - 05:10 AM |
