Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,038 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Is your tranny feeling like this?
![]() Send it to me and I will make it feel and perform like this! ![]() If your tranny is feeling its age, grinding, and popping out of gear I have the solution for you! If you have checked the other, outside of the tranny causes for these symptoms and found them to be ok then your tranny may be in need of a rebuild. Some outside of the tranny causes for some of your shifting woes: -Shifter bushings along the shift rod -Cone set screws -Tranny cable adjustment, shifter adjustment -Clutch, TO bearing, pressure plate -Engine and tranny mounts So, you have checked all of the above and it is still not working as it should. What do you do!? Send it to me! Repairs, modifications, conversions, you name it. I am interested in getting your car shifting correctly and lasting a long time while providing you with the greatest value and service. If you have questions I would be happy to help you. If you want to take pics of your gear stack and get an opinion feel free to contact me. Do you want to bring it by and have me take it apart to diagnose it? I will gladly do this, and for free. I will diagnose any tranny for no charge. I have a great stock of excellent used internal parts for much less than new with no loss in performance, as well as new, if you are interested. I have many different gear sets. I highly recommend all new main bearings; input shaft (x2), pinion shaft (x2) and differential (x2). I stock these bearing set at far less than retail. For shipping instructions, PM me. Any questions feel free to PM me (IMG:style_emoticons/default/wavey.gif) For more info, click the link to my web page in my sig below. Here is also a link to an excellent thread by DNHunt on how to rebuild the tranny if you want a basic overview http://www.914world.com/bbs2/index.php?sho...=40904&st=0 |
Dr Evil |
How to remove the stack from you tranny out of the car:
Step 1. Remove the shift console and the reverse switch with its pin ![]() ![]() Step 2. Remove tail cone. Be ready for the reverse gear and its little bearings to fall out. You should now be looking at the business end of the tranny gear stack. Step 3. Select 5th gear by taking a socket extension and pushing in the 4th/5th shift rod. Its ok to use a hammer, just dont beat the hell out of it (IMG:style_emoticons/default/wink.gif) (4th and 5th Shift rod in neutral) ![]() (5th gear selected) ![]() You can now remove your gear stack by lifting at the intermediate plate. ***NOTE*** When you remove the intermediate plate you will have some gaskets between it and the case. These are of a particular thickness and need to be replaced with the same to keep the pinion shaft depth the same. Use a micrometer to measure the thickness of these (usually more than one) and keep that number handy. When you reinstall you need to measure the gaskets that come with the new kit and replace with ones that are of the same thickness. Also, here is a link to Red-beards article on how to fix 1st with the tranny in the car. It can be used as a guide to how to remove the stack in the car. http://home.san.rr.com/pb914/rebuild/ |
Dr Evil |
So, now you have recieved your rebuilt gear stack and you are very happy (IMG:style_emoticons/default/biggrin.gif) How do you reinstall it?
Like so: Step 1. Select 5th gear on your gear stack. ![]() Step 2. Place the correct thickness of gaskets on the tranny case rear. Step 3. Place the case on blocks leaving extra room under the center for the drive shaft as it sticks out farther than the bell housing. Allign the stack, intermediate plate and drive shaft in the case and lower into position. Be careful of the output seal for the drive shaft. Make sure the drive shaft moves through it with out catching the lip and causing the spring inside it to come out. ![]() Step 4. Once the stack is installed, reassemble the 1st/rev gear stuff (make sure the flat needle bearing is UNDER the gear on the intermediate plate side!). Now put the tail cone back on. Step 5. It is now time to put the tranny back into the neutral. In the first pic you can see the shift rod notches are off center. Take a screwdriver and push the 5th/4th shift rod so it is centered. It should look like the second pic. ![]() ![]() Step 6. Once in neutral, put the shift console back in. The shift console only gets the O-ring. The gasket that comes with the seal kit is for the plug of the tail shifter that goes there, not for the side shifter console so don't use it. Step 7. Reinstall the reverse pin and switch. Install the tranny and enjoy! |
Dr Evil |
Next to come, how to allign your shifter.
i love porsche |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,547 Joined: 6-May 04 From: Nutley, NJ Member No.: 2,030 Region Association: North East States ![]() |
that looks great...i just got my sideshift..now i gotta start saving again
do you have any need for used parts or a case or anything, i have a partially dissasembled tailshift...dunno if/what kind of used parts you might use |
Dr Evil |
You may be able to use some of the parts for your own tranny. We shall see.
john grier |
Member ![]() ![]() Group: Members Posts: 303 Joined: 27-June 04 From: Hermitage, Tn Member No.: 2,265 Region Association: South East States ![]() |
Mine might need a rebuild,
I also have a 901 that I got with a parts car, Can you do anything with that? Witch tranny is better? Thanks John |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
rock on mike!
Dr Evil |
SGB |
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States ![]() |
I know what I want for Christmas! Of course the gear stack may not make it too you until February...
Bill Smith |
Member ![]() ![]() Group: Members Posts: 169 Joined: 2-May 06 From: Keyser, WV Member No.: 5,964 ![]() |
how much for a rebuild of a stock tranny and also install limited slip or Quaff? Have several Trans but not limited slip. Live near Cumberland, MD
Bill |
Dr Evil |
Hey Bill,
PM me with exactly what you are lookng to do and I will see if I can get a time set aside for ya. Thanks, Mike |
mrhurtalot |
VRRRRRRROOOOOOOOOM! ![]() ![]() Group: Members Posts: 323 Joined: 5-October 06 From: Yukon, Oklahoma Member No.: 6,996 ![]() |
whats the best shipping from mid oklahoma for a full transmission?
i dunno whats wrong exactly, but cars not drivable. driving it kind of hard (after a clutch disc pressureplate and thowout replacement) and i get this loud CRACK and now the car rumbles when in gear and has no power to the wheels. |
Dr Evil |
Hey man, let me try to save you some money. If you have a "CRACK" and now nothing goes then your box may be done for as you may have just put a bunch of metal pieces through your diff. It may be in you rbest interest both money and shipping wise to pull the stack out as per my instrucitons and look at the teeth on your pinion and your differential. If they are gauled you would do better to have me get you a core tranny down here and rebuild it. A core would only run you about $75 over what shipping yours to me would cost. I have shipping instructions in teh first post. Coast to coast on GreyHound is about $70 so you should be a littl eless since you are closer. If you want to talk in more detail about this, feel free to PM or email me.
spl914 |
Newbie ![]() Group: Members Posts: 10 Joined: 5-June 03 From: Fort Ashby, West Virginia Member No.: 790 Region Association: None ![]() |
Dear Dr. evil,
I have a '74 914. It has a 2.0L motor and the trans keeps popping out of 2nd gear. (IMG:style_emoticons/default/headbang.gif) I followed all your previous advice of things to try before calling you. I am desperate in need if a gear fix. (IMG:style_emoticons/default/smash.gif) Can you help me? I'm located in the panhandle of WV and can deliver the unit personally. Steve (304) 298-4216 |
Dr Evil |
Steve,
Yup, I can help you. The only thing is that I am booked until the end of the month. If you want to schedule a time in Sept to get this done then there will be no problem and a quick turn around. Thanks for reading the whole post above and trying all the things I listed. I constantly have to refer people back to it and it takes time to do such. Youare already a step ahead (IMG:style_emoticons/default/thumb3d.gif) (IMG:style_emoticons/default/welcome.png) |
NecronomiconJules |
Newbie ![]() Group: Members Posts: 7 Joined: 3-January 07 From: CA Member No.: 7,422 ![]() |
Dear Doctor,
I have a souped-up 3.0 SC engine mated to a side-shifter 901 with a ZF LSD. Now for the bad news: - 2nd and 3rd grind if shifting occurs anywhere near top RPM's; oh, if I wait > 2 seconds they don't, but by then I'm doing 3 Mph - 1st and reverse grind when engaging from idle after holding the clutch down for < 3 seconds; this one I can live with, and provide FYI I'm a complete mechanical ignoramus, with no hope for reformation any time soon. Can you help me? What happens if surgery reveals terminal condition in there? Can you source parts, etc.? $500 all going well, really? Cheers, J. |
Dr Evil |
J,
PM coming. (IMG:style_emoticons/default/biggrin.gif) |
carr914 |
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 124,334 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States ![]() ![]() |
Doe Dr Evil do 915s?
T.C. |
Dr Evil |
Yup, I do. (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 2nd April 2025 - 12:38 PM |
