John Kelly |
Senior Member ![]() ![]() ![]() Group: Members Posts: 692 Joined: 1-May 03 From: Moclips WA. Member No.: 640 ![]() |
Hi Folks,
Here is a picture of the engine I'm scraping up cash for. If you have any VW type1 hotrod buddies looking for parts, please show them my parts for sale page: http://allshops.org/cgi-bin/community/comm...d=9980142897618 Yes I'm coming over to the dark side...2.6 type 4 Motec fuel management TMW throttle bodies, Pauter internals etc. I plan to make a new fan shroud from aluminum. I think this will look pretty good in the back seat of my Ghia. Also an easy installation to the 901, has nice exhaust so I won't have to do a bunch more fabrication...besides all the surgery required to fit it all in the Ghia, that is. John www.ghiaspecialties.com Attached image(s) ![]() |
need4speed |
Member ![]() ![]() Group: Members Posts: 339 Joined: 11-April 03 From: Arroyo Grande, CA Member No.: 564 ![]() |
er - MID engine? Major surgery, indeed!
(/me scrounges around for the "This thread is worthless without MORE pics" icon. . . ) |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
QUOTE(need4speed @ Oct 15 2003, 08:48 AM) er - MID engine? Major surgery, indeed! (/me scrounges around for the "This thread is worthless without MORE pics" icon. . . ) here you go (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
Britain Smith |
Nano Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 ![]() |
Where did you get that engine and how much was it???? That thing will be a beast...I thought my turbo motor would be bad ass...
-Britain |
cha914 |
MUSR 8 - 5lug conversion done wed - drive 500miles thrus ![]() ![]() ![]() Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 ![]() |
Wow....that thing is going to be a beast...what is the engine using for cylinders? Any more specs?
and yes...more pics (IMG:style_emoticons/default/tongue.gif) Tony |
reverie |
Senior Member ![]() ![]() ![]() Group: Members Posts: 783 Joined: 14-March 03 Member No.: 427 Region Association: None ![]() |
John, have you considered the Berg 5-speed transmission?
The Berg 5 has some good options: (1) a choice in Berg shifters with 0%, 40%, or 60% reduction in shifter travel, and (2) the "locker option" which locks the car in Reverse when you park it.. (IMG:style_emoticons/default/cool_shades.gif) - Roger |
John Kelly |
Hi Roger,
I'm going mid-engine, and have a rebuilt 901 from John Walker ...for less than a Berg unit anyway. Here are the stats as they are presented to me by the seller: Case: Porsche type4, modified for full flow oil, machined spot >faced the case to facilitate larger case bolts that fit great > >Heads: Porsche, big valve 48 intake 38 mm for the exhaust, berg >springs, ported and polished and matching manifolds, 1.48 Pauter >roller rockers, welded and relived valve covers. (i'd put CSP valve >covers but I don’t think they fit the rollers. > >Crank: Pauter, welded and cross flowed and stroked out to - 78MM and >hardened > >P&L: 103 mm Keith Black - Chevy 454 pistons with valve pockets > >High flow oil pump – setup for full flow > >Cam : webcamshafts - #86a specs are: >.435 lift times it by 1.48 rockers - .684 lift >290 advetised duration >252 duration at .050 lift off the cam >Strong mid range and top end for high performance mech. street >engines. Valve springs recommended > >Rods: Pauter 4340 Billet rods chrome moly - hardend > >Bernie bergamn shroud – rabbit alternator, Porsche fan (his design – >looks like a Porsche fan but of his design) > >Induction: TMW 45MM throttle bodies through itg filters > >Computer control – supplied by a Motec M4 with the advanced tuning >options, sequential injection, and distributor less ignition, 32bit >microprocessor – tunes the car 300 times a second, laptop >configurable > >Automotive exhaust pipes – stainless steel and slightly larger ID >than stock > >Muffler: triad “T”style glasspack , feeding two more glasspacks >and the exit are 4” tubes $6000 seems like a real good deal to me, only 1k on the engine...he's upgrading! He has over $12,000 into this one. Sorry no more pictures until I get the thing in the car, but first I have sell lots of stuff... John www.ghiaspecialties.com |
need4speed |
John,
I had fantasized about a mid-engine ghia in the past. In my dream - the decklid had been welded shut, and the whole back end flipped up like a 550. . . - but I reckon that the old engine compartment is actually big enough to be made into a trunk for storage. . . |
Britain Smith |
Damn...That is a great price...I think that the Motec M4 is worth close to that alone. Here are the specs of my turbo type-4 conversion for my 912. It is getting there.
Turbo Type-4 Info and Pics. Displacement: 2353cc Bore: Aluminum 930 98 mm, Flat-top, Aluminum Cylinders Stroke: 78 mm stroked, knife-edged, forged, counterweighted crank, dowel-pinned flywheel Rods: Carillo Rods Cam: Engle FK-10 Heads: 2.0L Heads, Flycut, 60cc matched, ARP Head Studs, Match Tuned Exhaust Stub Tubes Valve Train: Titanium Retainers, Racing Dual Springs (0.6" lift), Forged Hardened Valve Keepers Rockers: Pauter 1:1.48 Aluminum Roller Rockers Case: Blueprinted, line-bored, modified to breath easier. ARP Case Bolts Oil: Fitted with Type-1 style sump studs, 2-Qt Deep Sump, custom Billet Sump Plate Cooling: Sharpbuilt Upright Shroud, 911 11-blade Fan |
Lo-Fi Version | Time is now: 26th June 2024 - 04:56 AM |
